Originally Posted by BYprodriver
If you put 3.4 heads on a 2.7 you lost compression ratio & undoubtedly low rpm torque due to the bigger valves.
Hmmn, what head gasket was used? With the difference in bore size at a whopping 10.5mm of bore size difference I'd expect issues. What cams were used with this?
I think he is stating that he had a 2.7 and did a 3.4 engine conversion...
US Patent 8,992,089 &
US Patent 9,416,697
