Old 06-24-2013, 05:58 AM   #1
Drilling suspension turrets to enable camber adjustment.
So, a guy from the UK Boxanet forum has been discussing how a specialist geo shop has drilled his front strut turrets to allow for camber adjustment on the cheap.
Basically, you drill out the holes for the top mounts a bit to allow for a little lateral adjustment.
Anyone round here done this? Sounds like an attractive idea - could be done for very little money. You'd want to know what you're doing, obviously...
pothole is offline   Reply With Quote
Old 06-24-2013, 11:34 AM   #2
Carnut
AndyA6's Avatar
Yep, heard of. Done (not my car) on an Audi A6, works!
'14 Boxster
Old 06-24-2013, 11:50 AM   #3
woodsman's Avatar
common low tech/cost technique
Old 06-24-2013, 01:19 PM   #4
Does anyone have any experience and thus a rough idea of how much drilling translates into how much camber?
IIRC from my old E36 BMW roughly a cm gave about 2 degrees neg camber.
Also, would adding a little castor be a good idea? I seem to recall adding castor gave my old BMW a little extra meat to the steering feel...
Old 06-24-2013, 01:42 PM   #5
Increased caster will give you increased 'return' on the steering - i.e., the tendancy for the steering to want to center itself.
Brad
southernstar is offline   Reply With Quote
Old 06-24-2013, 03:32 PM   #6
The Radium King's Avatar
there is info on this board - I was searching this exact topic a few weeks ago. from what I recall you should change washers to ensure adequate grip so that the shock doesn't adjust itself, and the most you can get is about an additional -0.5 degrees (dependent on how much you have lowered your ride height).
after much deliberation I ended up buying ksport coilovers - just a bit more than half the cost of pss9's and come with front camber plates and rear adjustment built-in.
Old 06-25-2013, 04:17 AM   #7
edc
550 Anniversary
edc's Avatar
... :wave: ...
Old 06-25-2013, 05:15 AM   #8
Old 06-25-2013, 05:19 AM   #9
Only an extra 0.5 degrees? Bummer.
I've been reading around as well, saw that thing re the washers...
Old 06-25-2013, 12:18 PM   #10
woodsman's Avatar
I would think that the limiting factor would be that the shock tower has little room for travel in the tower 'bucket'. I wonder if something could be done at the other end- locating stops and an eccentric...? I'm installing ROW 030 right now and have done some tweeking so that I get .75" lower in the FR and .625" in the RR. I've read here that this will also increase my camber F-R. Are you getting new struts Pothole?
Old 06-25-2013, 01:15 PM   #11
edc
550 Anniversary
edc's Avatar
http://www.boxa.net/forum/index.php?showtopic=53075&&page=7
Of course there is only so much you can move the top mount before it will hit the inner arch, but you'd have a similar scenario with eccentric mounts.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
Old 06-25-2013, 02:00 PM   #12
Yeah, I have an M030 kit to go on which I want to combine with H&R springs, so am looking for cheap ways to tweak the camber. Also looking into adjustable track arm bushes...
Old 06-25-2013, 02:43 PM   #13
Do it right:
Cheap camber: Camber plates
Expensive camber: Lower adjustable a-arms
Old 06-25-2013, 04:14 PM   #14
I've never seen camber plates for a Box at a price I would describe as cheap.
Old 06-26-2013, 12:43 PM   #15
woodsman's Avatar
How much camber do you want Pothole? Anything beyond -.5 is going to diminish your braking ability and wear your tires out faster.
Old 06-26-2013, 02:12 PM   #16
Disagree. -0.5 is very, very mild and won't make the slightest bit of difference to braking, you'd have to have very, very extreme camber to compromise braking.
I've run miles more than that on the road before and not noticed any loss of braking performance whatsoever. Wear does go up a bit, but in my experience, I would draw the line at -2.5 for the road. Even at -2.5, the wear rate wasn't that bad.
Old 06-27-2013, 12:50 PM   #17
woodsman's Avatar
yea my experience is with showroom stock racing civics! I'm not sure what specs I'm going with on my street-only car. As it is, I have to drive at crazy speeds to get any serious slip (FUN) going.
Old 06-27-2013, 03:17 PM   #18
Sorry, I should have taken a bit more time to explain my position; I didn't mean cheap/expensive in terms of affordability. I was simply comparing the relative cost of camber plates ($300 used, $500 new) to the cost of adj lower control arms ($800 and up).
Old 06-27-2013, 03:47 PM   #19
edc
550 Anniversary
edc's Avatar
The drill is free. In the UK it would be almost impossible to find second hand eccentric top mounts. They are £300 here at least.
I haven't maxed out the camber and I'm not that low on M030. Lower and with a drill I would expect over -2 to be achievable maybe -2.5.
Old 06-27-2013, 04:56 PM   #20
I would also suggest considering the possible impact on resale value - buyers may not consider a car that has aftermarket holes (or enlarged stock holes) in the upper shock mount area.
