Originally Posted by The Radium King
there is info on this board - I was searching this exact topic a few weeks ago. from what I recall you should change washers to ensure adequate grip so that the shock doesn't adjust itself, and the most you can get is about an additional -0.5 degrees (dependent on how much you have lowered your ride height).
after much deliberation I ended up buying ksport coilovers - just a bit more than half the cost of pss9's and come with front camber plates and rear adjustment built-in.
Only an extra 0.5 degrees? Bummer.
I've been reading around as well, saw that thing re the washers...
