Old 06-21-2013, 12:48 PM   #1
pk2
03' 3.6l and IMS....Problems?
Hello,
I contemplating purchasing a 99 box that somehow received a 03' 3.6L motor. Is such a motor as susceptible to the same IMS failures (or "D" chunks) as the standard 2.5L & 3.4L's?
Also, Rated HP of said 3.6L
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 06-21-2013, 01:30 PM   #2
Moderator
From what I've read the D chunks were problems in 2.5l engines. 3.6l should yield 315hp & 273 lb ft. torque per Porsche listing. As far as an IMS, I think if you have it, it can be susceptible.
Old 06-21-2013, 03:22 PM   #3
seningen's Avatar
They are all more or less similar and to varying degrees have similar failure modes.
I have not seen a 3.6 with a d-chunk -- but I have seen cracked cylinder liners.
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 06-21-2013, 06:47 PM   #4
Yes, all of the M96-based engines (2.5L, 2.7L, 3.2L, 3.4L, and 3.6L) use an intermediate shaft and are susceptible to a bearing failure. How susceptible is a matter of great debate.
The comparable years 996 Turbo and GT- cars used a different engine design and do not have this concern.
Old 06-22-2013, 07:45 AM   #5
What kind of a 3.6? There are 3.6s that received the LN kit which strengthens the cylinder liners. Or 3.6s from a 911. Or maybe done with other parts. Before buying, learn what is really in the engine. Were there any upgrades done when the install was done? What ECU the thing is using? Any mods to the smog equipment that would cause you inspection concerns in your state?
Old 06-23-2013, 06:39 PM   #6
pk2
as far as i can tell it's just a stock 3.6.It apparently has a carra plenum but no claims of any internal mods. I guess Its just a crap shoot eh
Regards,PK.
