Old 12-18-2012, 03:28 PM   #1
AOS Replaced, now cannot shift beyond 2nd
Have a 02 Boxster S. Today I had my AOS replaced by a local generic auto mechanic, I provided part etc.
It is an experienced shop but not specific to Porsches.
When I picked up the car I quickly realized I could engage reverse, first and second but could not physically move the shifter to a position such that could engage third through sixth. :ah:
Tech put the car on lift and fiddled with shift linkage. We could then get all gears but after a short distance the problem reappeared.
They have the car tonight and my hope is this is a simple issue resolved tomorrow morning, however I know the AOS is in a position that is in the proximity of where the shift linkages connect to the tranny. So clearly they messed something up when AOS was replaced.
Any ideas as to what transpired?
Thanks in advance,
Joe in Atlanta
macnjam is offline   Reply With Quote
Old 12-18-2012, 06:54 PM   #2
1999 base
Meir's Avatar
The shifter cable has a ridicules locking tab. If it's not fitted properly, the cable will jump out of its support, and you will loose gears.
I truly hope and ( believe ) that's your issue.
Couple of minutes with consternation, he will get it right.
Old 12-18-2012, 07:16 PM   #3
Moderator
What Meir said is very true. This happened to me when I was driving back from a car meet with Homeboy981 and I had the exact symptoms as described. Remarkably, I drove and started out off in 4th gear, back to a garage to pop the cable tab in.
Old 12-18-2012, 07:28 PM   #4
Schatten-Baum-Mechaniker
This is what it looks like with the clips locked in place. Zip ties are there to keep them from popping out.
Tommy
2000 Boxster S
1973 914
tommy986 is offline   Reply With Quote
Old 12-19-2012, 06:04 PM   #5
I have zip ties on mine too. It's a crappy design.
Old 12-19-2012, 06:52 PM   #6
Porsche "Purist"
Paul's Avatar
Always use new clips.
986-424-411-00 Clip transmission cable (at transmission) 2 per car $3.59 retail
1987 924S. 2002 996TT. PST-2
Old 12-19-2012, 07:10 PM   #7
Porsche "Purist"
Paul's Avatar
Old 12-19-2012, 07:12 PM   #8
Porsche "Purist"
Paul's Avatar
Old 12-20-2012, 01:37 PM   #9
Autobahn Glanz
WhipE350's Avatar
Ya they messed it up. I used zips also. After I did my transmission and IMS I had one pop off and only had 2nd, 4th, and 6th gear to drive home in...no problem though fixed it in minutes.
Old 02-05-2023, 05:03 PM   #10
Does this get too hot for zip ties?
Anyone melted the zip tie?
Is safety wire better to use?
01 Boxster S 6Spd, Speed Yellow w/84k miles. | 991.1 911 C2 7spd Manual | 01 996 C2 -6spd - Green Machine - My baby | 997.2 C2S 6spd | 2x 01 Boxster base
professorman is offline   Reply With Quote
Old 02-05-2023, 05:34 PM   #11
Porsche "Purist"
Paul's Avatar
I never reuse these as they are easily damaged when removing. I have never had an issue when using new ones.
Old 02-06-2023, 11:09 AM   #12
I used a heavy duty zip ties here as a precaution just in case the OEM clip fails, and never had an issue with the zip ties here.
Old 02-06-2023, 11:48 AM   #13
Awesome! Great to hear. I will get some heavy duty zipties.
