Old 05-10-2012, 07:12 AM   #1
You can do it from either side, but if you are going to be rotating the V-levers you will have to pry off the end that is pressed onto the V-lever's steel ball.
The important thing is to operate the top so that there is no pressure being exerted by the large spring inside the black "hydraulic" pushrod. It's doable in the service position.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 05-10-2012, 08:04 AM   #2
Regards, Maurice.
today I released the top from the pushrod levers and the top itself is as free to move as a free thing on a free day - so its not the top binding. I operated the switch and the binding is still there. Clamshell jerks and does not close properly.
Next I will disconnect the clamshell - though not sure what you mean by your last para. If I pry the ball end off will this have the effect you talk about?
Then if the transmission operates correctly am I looking at the black hydraulic rods being bad? Is there a check to confirm that?
Simon
ferrytrip1 is offline   Reply With Quote
Old 05-10-2012, 08:24 AM   #3
Simon
Simon:
If the clamshell is jerking, you should also verify that the rails in which the black plastic sliders ride back and forth are well lubricated. It could be as simple as that.
The last paragraph of my previous post means that in certain positions of the top, there is a great deal of pressure applied by the black "hydraulic" pushrods to hold the clamshell shut. When the clamshell is down, it is very difficult to pry off the black pushrods off the steel balls on the V-lever. If you pry off the pushrod from the steel ball on the V-lever, the clamshell should move just as freely as your now- disconnected canvas portion of the top does.
The black pushrods only go bad when their ends sometimes get bent. If you can get one of those in a vise and apply enough pulling pressure, you can test whether the large spring inside is intact and functioning properly. It takes a LOT of force to pull it.
Regards, Maurice.
Old 05-10-2012, 11:54 AM   #4
Simon:
Regards, Maurice.
got it - thank you. The guides do look lubed but will check.
If I release the pushrods at the v bar so the xmsn does not drive anything will the mechanism go full travel from open to closed - ie the xmsn does not know there is no roof attached so it would just rotate as normal and stop on the limit switches. My thinking is if this is right then if both sides are ok and they rotate then the only thing left is the pushrods or the clamshell guides as you say.
will look first thing tomorrow
Thanks, Simon
YNWA
Old 05-10-2012, 07:24 PM   #5
Thanks, Simon
YNWA
Yes, with all four pushrods disconnected, the V-levers should rotate fully and stop at each of the two limits if the microswitches inside the transmission are functioning properly.
Regards, Maurice.
Old 05-10-2012, 09:23 PM   #6
The pushrods are off. They look ok, you say they are sprung - they both look solid - neither end moves. I have no access to a vice so must assume they are ok.
When I get a help (early here) for somebody to press the switch while I watch the XMSN I will test the travel.
Simon
