Old 05-10-2012, 07:12 AM   #1
schoir
You can do it from either side, but if you are going to be rotating the V-levers you will have to pry off the end that is pressed onto the V-lever's steel ball.
The important thing is to operate the top so that there is no pressure being exerted by the large spring inside the black "hydraulic" pushrod. It's doable in the service position.
Regards, Maurice.
schoir is offline   Reply With Quote
