04-12-2012, 08:51 AM
IMS Guardian
I just had the IMS Guardian installed on my car, I felt it was a better out lay of money than a IMS retrofit at this time. I was wondering if there was a lot of other Porsche owners going this route. I feel really great about having it installed and when they installed the guardian, they found that the oil pick up tube had silicone up against the mesh from the orginal engine build, Jake said it probably wouldn't have made it through the summer. It gives me a lot of peace of mind to know that I have something to protect my engine from failure.
04-12-2012, 09:22 AM
Engine Surgeon
US Patent 8,992,089 &
US Patent 9,416,697
04-12-2012, 09:33 AM
Where is this sealant used?
986 00S
04-12-2012, 09:39 AM
Engine Surgeon
This sealant was used in numerous places on the engine. This can be made worse if someone does a cam cover or sump plate job and uses the wrong sealant or too much sealant.
The sump and cam covers on this engine are OEM and have never been resealed. I have been seeing this for years, and have seen some engines fail from this alone, especially on the track where oil starvation is always a concern, even if the oil pick up tube isn't blocked.
US Patent 9,416,697
04-12-2012, 10:25 AM
recycledsixtie
I am with u 100% . I have had my IMS guardian installed about 4 months ago and I don't really worry about the IMS anymore. My 2001 Boxster base had less than 40k miles on it when I bought it a year ago. I don't really like to spend $$$ on my Box unless I have to. A couple years from now I might need a clutch job and then I will get the IMS replaced. In the meantime I enjoy the ride.
04-12-2012, 10:50 AM
your car had worms!
04-12-2012, 11:06 AM
IMS Guardian
That is exactly what went through my mind. that and Holy Crap!!!
04-12-2012, 11:54 AM
Ivermectin will fix that right up!
2001 Boxster S 3.6L, Zeintop
04-12-2012, 11:56 AM
Had a similar experience last weekend when I installed my IMS guardian, not as bad as Travis though . When photo was taken some of the " worms" already had left the filter
Can only recommend everyone to lower the sump next oilchange. Guess it adds an hour or so. Wellspent time.
04-12-2012, 05:39 PM
Sorry to sidetrack this thread but... what torque setting is everyone using for the sump bolts?
Rich F
somewhere
past: 2000 Boxster S
past: 2010 Boxster S
04-12-2012, 06:20 PM
Oil sump bolts should be torqued to 7.5 ft-lbs or 10NM. (yes, somewhat light).
04-12-2012, 07:41 PM
I have dropped my sump and found nothing just wondering if this sealant would be a one time accumulation or can it appear later in the engines life....
986 00S
04-15-2012, 03:38 AM
So, how much sealant is too much and what would be the right way to seal? I did the guardian and used Loctite 590 around the outer edges of the plate. About 1 mm or so think. Did notice they squeezed out when torqued but have been concerned some may have made squeezed into the inside.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
04-15-2012, 07:16 AM
A very small bead is all that is required, too much and you get the squeeze out that causes problems...........
04-15-2012, 07:59 AM
But, I don't get the point in putting a small bead. Shouldn't the seal be all around the joint and not just a few beads in a few places?
Anticipating the squeeze out I put the seal on the outer most edge of the bottom pan. I let it dry for over a day. Still the possibility of an issue?
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
04-15-2012, 08:46 AM
The bead needs to be small and continuous; it should also go around the bolt holes to prevent seepage at the bolt heads, which is a fairly common issue. The two mating surfaces are both machined true, so very little sealant is needed. Most DIY projects use way too much sealant, and end up causing more problems, much like Jake pictured above. This is also a major factor in why the green cam plugs blow out after a DIY reseal on the cam covers; squeezed out sealant blocking the oil returns. For some reason, when it comes to sealant applications, everyone seems to think that "if one is good, and two is better; then forty seven must be just right". It isn't. Use the 5900 sparingly………..
04-15-2012, 10:22 AM
Thanks for advice. I don't think I used it too much and was aware it might b an issue as I saw some sealant around the baffles on the sump plate. I'll have to remove the plate during the next oil change and inspect to be sure. I plan to do that in 1k as I just did the bearing change and IMSG.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
05-25-2012, 12:35 PM
I'm a little sceptical that the IMS Guardian will give enough, or any advance notice of an IMS failure.
Seems that the Guardian needs to have metal bridging the two magnetic contacts
to trip the alarm but in my reading of all the reported failures the bearing disintegrated rapidly with little or no other audible symptoms.
Perhaps if enough small shards of the bearing cage came off over time, some pieces might bridge the contacts and stick to the magnets in theory.
Bigger pieces and bearing balls might settle elsewhere and never make it past the Guardian to get captured by its magnets.
I suppose an acumulation of finer particles might form a bridge as captured by the magnets over time if the failure is a slow progressive deterioration.
Seems like you might only be getting a marginal improved chance of catching a failure in progress.
I think the guardian may produce a false sense of security rather than a reliable method of IMS failure avoidance.
I think the money is better spent simply replacing the bearing since it might only cost you another $700 to actually remedy the problem entirely.
I expect when that Guardian does Alert, I would think you best stop immediately and get a tow to your garage (say $200 or more). Then a diagnosis, $200+, so now we are talking only $300 more to make a schduled garage appointment rather than driving till it nearly fails and being stuck out somewhere.
Its just my opinion of course but I have not seen statistics showing how many Guardians out there total, how many grenaded engines that had a Guardian but could not Alert in time to avoid the failure, and how many have Alerted and saved an engine.
Are there numbers to back up the performance of the Guardian?
05-25-2012, 01:48 PM
If you had ever seen an M96 that was "caught" just as the IMS was near death, but had not totally failed yet, you would be appalled by the amounts of ferrous debris found in the sump and oil filter. These things start grinding themselves to death long before the timing jumps, so there is more than enough metal to trip the sensor.
You might want to refer your question on "numbers" to Jake at Flat Six, they are the ones that "get the call" when these things go into alert, so he would be the one to best address that.
05-25-2012, 02:55 PM
This was the source of engine failure in my friend's spec boxster. This can happen at ANY time - you can check the oil pickup today and have this happen next month. No telling when the sealant is going to come off.
