Thread: IMS Guardian
Old 04-15-2012, 09:46 AM   #16
JFP in PA
The bead needs to be small and continuous; it should also go around the bolt holes to prevent seepage at the bolt heads, which is a fairly common issue. The two mating surfaces are both machined true, so very little sealant is needed. Most DIY projects use way too much sealant, and end up causing more problems, much like Jake pictured above. This is also a major factor in why the green cam plugs blow out after a DIY reseal on the cam covers; squeezed out sealant blocking the oil returns. For some reason, when it comes to sealant applications, everyone seems to think that "if one is good, and two is better; then forty seven must be just right". It isn't. Use the 5900 sparingly………..
