Old 01-19-2012, 05:36 PM   #1
Leak Around Transmission Linkage
I have had a small leak at the rear of the car for a long time, like a year or two. It appears to be getting worse. I got up under the car and it appears to be coming from where the transmission linkage joins the transmission. Anyone else have this problem?
Thanks,
Tom
Tom
02 Boxster S
Lapis Blue
tombea is offline   Reply With Quote
Old 01-19-2012, 06:43 PM   #2
Autobahn Glanz
WhipE350's Avatar
It sounds like it could be the RMS (Rear Main Seal)...or worse the IMS. From my reading it is usually the RMS. What's the year and mileage of your car. The RMS can ooze for years and drip. My car is a 2000 'S' and had the old style seal, you might have it too. Mine wasn't dripping but when I went in to replace the IMS I could see the RMS had oozed slightly.
Old 01-19-2012, 07:11 PM   #3
Brad Roberts's Avatar
Tom,
I know what the problem is.. and you are not going to like it
Porsche will have you replace the entire tail section. We repair them.
I'll show you how we do it...
hang on
B
Old 01-19-2012, 07:19 PM   #4
The bronze bushing is worn out were the shift selector enters the tranny (it's leaking from the side correct?) I'll post how we do it when Tom responds
B
Old 01-19-2012, 07:35 PM   #5
Autobahn Glanz
WhipE350's Avatar
Thanks Brad...Tom ignore my babbling...I didn't read you post closely...sorry tired.
Old 01-19-2012, 07:37 PM   #6
It's only 10:30pm!! your time!! Tom is probably in bed already
B
Old 01-19-2012, 08:24 PM   #7
Autobahn Glanz
WhipE350's Avatar
Tired eyes from reading the yellowbird conversation . So entertaining I couldn't stop reading...just wish I understood half of what they are talking about. Keep up the good help.
Old 01-20-2012, 06:10 AM   #8
DFW02S's Avatar
I think Brad has it nailed.
It's a $3 part that you can't access without removing the transmission.
Prepare yourself.
Have them check the syncho's while they're in there.
DFW02S is offline   Reply With Quote
Old 01-20-2012, 10:11 AM   #9
We pull the rear cover off with tranny in the car
We machine the case to accept a larger bushing.
Old 01-20-2012, 05:12 PM   #10
That's it Brad. What will removing the tranny and replacing that bushing run?
By the way, thanks for your diagnosis. I'm sure that is the problem.
Tom
02 Boxster S
Lapis Blue
Old 01-20-2012, 05:17 PM   #11
You're right Brad:-)). I'll be 72 my next birthday and bedtime gets earlier.
Tom
02 Boxster S
Lapis Blue
Old 01-20-2012, 05:41 PM   #12
I hope I still have the Porsche "drive" when I'm 72!!!!
Porsche wants $645 for that rear cover (not including labor)
I fix them turnkey for $600 out the door.
The bushing Porsche utilized is too thin. It doesn't last. We bore out the hole and make our own press fit bronze bushing (factory used bronze, but it has no way to receive gearlube) We cut a spiral path in the new bushing for oiling, then install a new $4 seal. It's not the seal that is bad.. next step is second gear will go out because the shift selector cannot engage it properly do to the slop in the bushing.
Old 01-20-2012, 05:43 PM   #13
While the rear case is in our machine
Yes. I document everything.. can't always find it when needed, but I document everything we do. I just don't share all of it
B
Old 01-21-2012, 01:22 AM   #14
@ Brad Roberts: Wish there were people as knowledgeable as you and with your reasonable rates around where I live... Keep up the good work.
Old 01-21-2012, 02:57 PM   #15
DFW02S's Avatar
+1
I would have been happy to have this process done when I replaced that stupid little bushing!
Old 01-24-2012, 12:01 PM   #16
Within the next few years, you will see a book released by a very popular EX Porsche employee. The title of that book will be something along the lines of "Surrounded by Idiots"
The book is about how the accountants took over Porsche in the early 90's..
Things like this bushing remind me of why that book was written.
B
Old 01-24-2012, 12:24 PM   #17
Just an FYI:
Second gear will go out if those of you with this same problem (I'm receiving a lot of PM's about this) do not get it rectified quickly. The problem goes from a $600 fix to a $3000 fix very quickly.
and this is what I hear all the time... "oh, I'll buy a good used tranny"
and you will end up with the exact same issue in the not to distant future....
B
Old 01-24-2012, 06:25 PM   #18
Originally Posted by Brad Roberts View Post
Just an FYI:
B
Brad,
You mean the infamous synchro will go out, the actual gear, or both? I suppose a bad synchro that goes unattended will eventually require second gear replacement too, though? I've also read about popping out of gear...
wanna986 is offline   Reply With Quote
Old 01-24-2012, 07:09 PM   #19
This is the precursor to the popping out of gear.
The slider will go bad first, then it will take out 2nd gear dog teeth (which are friction welded to the gear)
ask me how I know
$600 in the above pic alone.. add in the gear at $420 plus labor...
B
