Old 01-24-2012, 06:25 PM   #18
wanna986
Originally Posted by Brad Roberts View Post
Just an FYI:
Second gear will go out if those of you with this same problem (I'm receiving a lot of PM's about this) do not get it rectified quickly. The problem goes from a $600 fix to a $3000 fix very quickly.
and this is what I hear all the time... "oh, I'll buy a good used tranny"
and you will end up with the exact same issue in the not to distant future....
B
Brad,
You mean the infamous synchro will go out, the actual gear, or both? I suppose a bad synchro that goes unattended will eventually require second gear replacement too, though? I've also read about popping out of gear...
wanna986 is offline   Reply With Quote
