Old 12-09-2011, 08:40 AM   #6
Do a Tune up, clean the throttle body with alcohol until all of the black dirt and gunk is gone. Remove MAF sensor using T20 torx screw you can buy from Home Depot and spray the contacts with an electric parts cleaner, which you can also use to clean the throttle body instead of alcohol. Put everything back together and see how it runs. CEL light might go away. Car will definitely run better.
ProjectM96 is offline   Reply With Quote
