Old 12-13-2011, 06:15 PM   #15
shlim8
Originally Posted by Bala View Post
Measured the rotors. They are 23mm in the back and 26mm in the front. Couldnt get a an accurate read but it a tad more than these values. The minimum is 18 in the back and 22.6 in the front as per PP? Sounds too low for me but Pp says it is when i spoke to them. Replacing the pads and sensors so will get a good look when in there. Maybe due for a change next time around.
Those min figures could be for a base boxster... looked like the thickness of my stock base rotors when I swapped them out..
I think the S rotors are 4mm thicker or so... 28mm (F) and 24mm (R) if I remember right. So I highly doubt the min would be that low.
shlim8 is offline   Reply With Quote
