06-04-2011, 05:03 PM
S won't shift into gear?
Left my 2001 Boxster S in an underground carpark today, was running fine. Came back 2 hours later and it would not go into any gear. The shifter moves freely but there just seems to be no gears to select.
Don't know what has happened. Seems odd how it can randomly do this? My clutch is on it's way out but I doubt it is anything to do with that..
Any ideas?
06-04-2011, 05:11 PM
Does the shifter move freely without pushing-in the clutch peddle? All gear positions? Does the shifter feel any different?
06-04-2011, 05:12 PM
Yes, it will move freely without engaging the clutch. It is like there is no gears to choose. Really odd..
06-04-2011, 05:30 PM
What you’re describing it seems your linkage cables got disconnected, at the shifter or at the transmission??
06-04-2011, 05:31 PM
Thought it was something like that. How hard is it to remove the center console? I can't seem to find any information/tutorials showing you how to do it.
06-04-2011, 05:48 PM
I have not opened my console but I know other members of this forum have, maybe someone will chime-in.
I would get underneath the vehicle and look at the transmission end of the cables while having a friend move the shifter. There is a great picture on this thread: [url]http://986forum.com/forums/showthread.php?t=28990[url] showing the ends of the cables that connect to the transmission linkage. See if you have movement there or if the cables are disconnected.
06-04-2011, 06:15 PM
After checking again, it seems to go into 3rd, 4th, 5th and 6th. Going near the left (1,2,R) is very "loose".
Where is that part located? Think I can get access to it without jacking the car?
06-04-2011, 10:32 PM
I have worked on the linkage only while under the vehicle. You might be able to get to the transmission linkage if you remove the rear passenger side wheel, I'm not sure, but in either case you will have to raise the vehicle.
06-05-2011, 11:59 AM
Ok, bought a jack today and took a look:
It seems that the bottom most one is out of place. I tried quickly putting it back in, but it is awkward to get at. Any tips?
Also, Is it as simple as that? The top most one seems to have a loose washer as well. Issue?
06-06-2011, 07:51 AM
Schatten-Baum-Mechaniker
the brackets in the picture must be firmly seated and the retaining clip should be in place. Best viewed with wheel removed.
Tommy
2000 Boxster S
1973 914
06-06-2011, 02:00 PM
These look good to me, shift to neutral to check alignment, but if they are connected I would not change adjustment. Easy to remove console as all panels pull off easily & ashtray comes out after removing T10 torx screw in bottom. Check pelicanparts.com tech info section for good trans repair pics.
06-06-2011, 06:28 PM
Crazy Austrian
Northing is good here. the bottom outer cable is more than half way out of it's holder and the top one is completely out of the holder. It will not shift unless the outer cable is mounted correctly.
Crazy Austrian 007
http://www.ws-ab.com
06-09-2011, 10:43 AM
So, I had them put back into place, but while driving today they both came out again, which driving.
I'll have the clutch out next week, so I'll be able to take a better look then.
06-09-2011, 04:23 PM
Porsche "Purist"
The retaining clips are easily damaged when removing the tranny cable ends. I'm guessing whoever worked on the car last damaged them and reinstalled the cables without buying and installing new retaining clips.
1987 924S. 2002 996TT. PST-2
06-09-2011, 07:20 PM
Crazy Austrian
There are very small detent's in the bracket into which the retaining rings must be inserted, You may have to bend them to hold in place or purchase new ones.
Crazy Austrian 007
06-09-2011, 09:30 PM
06-10-2011, 12:07 AM
06-10-2011, 04:51 AM
Porsche "Purist"
986 424 411 00
OEM-98642441100 Retaining clip, mount, cable, for 2 $3.75
06-10-2011, 03:46 PM
Excellent, thank you.
06-02-2015, 09:17 AM
Hello I'm having the same symptoms as OP but when friend checked cables underneath today he said they looked good? I took the car for a short drive and it seemed fine after sitting for 7 months. The cables were not loose at all. Is there any other area I should be looking at? I noticed in another thread someone mention pressure plate but if it was that would it only give problem sometimes or all the time?
Boxster Blues
