Old 02-06-2011, 07:33 AM   #1
Flywheel bolt torque?
Having done so many other jobs on the car now I want to do my first ever clutch job and have been reading up on the procedure. I've got the 101 projects book but he mentions two different tightening procedures. One was a 90deg final turn and the other was 120deg. What is the actual correct procedure for these bolts?
Chris
87 944S brought back to life
Dragonwind is offline   Reply With Quote
Old 02-06-2011, 10:15 AM   #2
Have you posted this question on the Pelican tech forum? I'm sure Wayne would be more than happy to address it.
http://forums.pelicanparts.com/boxster-cayman-forum/
Old 02-06-2011, 10:25 AM   #3
There are not two procedures, there are two stages; for the flywheel bolts (new only, do not reuse), torque to 19 ft lb, then tighten another 120 degrees of rotation to gain the correct bolt stretch. For the pressure plate, torque to 17 ft lb.
Old 02-06-2011, 11:36 AM   #4
JAAY's Avatar
It is an easy job. I'm not too far away if you get stuck and want help.
Old 02-06-2011, 01:00 PM   #5
Thanks guys, and JAAY that's very kind of you. I thought the 120 was the proper one but in one photo he wrote tighten to 50%, then final torque, then 90deg further. The 2nd just mentioned the 120 degrees. I'll post the the Pelican tech too.
Thanks,
Chris
Old 02-06-2011, 08:08 PM   #6
Crazy Austrian
harryrcb's Avatar
Hi JFP, just a quick question, I know the bentley book says 120 but in my Porsche manual it says 18 and 90 - why the difference and which is right?
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 02-07-2011, 11:20 AM   #7
I just took a moment to look it up in my OEM manual set, and in Group 3, 30-1, page five under torque specs for dual mass flywheel, it says “25 Nm (19 Ft. Lb) plus 120 degree tightening angle”. As we kept this set current with all updates, I believe this is the most current info; yours may be from an earlier text.
Old 02-07-2011, 11:59 AM   #8
JFP,
Out of curiosity, if you use Locktite red on these bolts (4 insurance) before applying torque, would the real torque values be too different? Since you are supposed to oil the threads..
Old 02-07-2011, 12:14 PM   #9
You should be using some type of lubricant on any torqued fastener, be it anti seize, oil, or thread locker. I’m sure there are small differences between each, but that there would also be a larger variance if the fasteners were assembled dry. I think ARP did a “white paper” on this subject several years ago, so you may want to check their site for more info.
In any case, by far the most accurate way to assemble with fasteners is to measure bolt stretch rather than torque. This is one of the reasons why Porsche uses “micro encapsulated” single use fasteners in several locations (like the flywheel), and uses torque specs followed by “tightening angles”, which are attempting to take into account the stretch factor………
Old 02-07-2011, 04:53 PM   #10
Crazy Austrian
harryrcb's Avatar
Thanks JFP , I must not have the updates, do you know where I can get those?
Crazy Austrian 007
Old 02-07-2011, 07:14 PM   #11
You can no longer get them; they went out of print when Porsche stopped printing the manual sets and switched to an electronic subscription system at the time of the advent of the PIWIS system. You may be able to find someone selling a print copy of the last updates somewhere on the web…….
Old 02-07-2011, 08:48 PM   #12
Crazy Austrian
harryrcb's Avatar
Thanks. BTW what do you think of either Mitchell or Alldata ? Do they have enough data to make it worthwhile. I believe Mitchell has an electronic manual for single car for around $29/yr and alldata has a similar offer for around $23/yre or 44 for 5 yrs
Crazy Austrian 007
Old 02-08-2011, 11:07 AM   #13
Both are OK in general, but all these services have weak spots with any particular make, and Porsche is anything but an exception to that rule. While often hard to decipher, and totally dependant on hard to find and expensive specialty tools, the OEM manuals are still the best.
Old 02-08-2011, 12:05 PM   #14
Crazy Austrian
harryrcb's Avatar
I agree about the OEM manuals but it does not apply to the new cars I have a project that I'm working on and need the 09 Manual but cannot afford the $5k per year to access the electronic one.
Crazy Austrian 007
Old 02-08-2011, 01:50 PM   #15
Well, they were offering a deal on subscription pricing, if you lease a PIWIS system, for $18,000 a year, they give you access to the manuals for $1,000.............
Seriously, this subscription nonsense is just another “intellectual property” doge designed to keep independents away from the cars, pure and simple. And I used to think that the 986 and 996 printed manual sets were overpriced at $2,300 (each) for the set….
Old 02-08-2011, 06:50 PM   #16
Crazy Austrian
harryrcb's Avatar
Gee what a deal, where do I sign up? You are dead on about keeping independents at bay.
Crazy Austrian 007
Old 07-08-2015, 01:27 PM   #17
JFP and Team,
I finally have my adapter plate in my Boxster EV conversion and am going to be assembling the drive train - DC Motor + DMFW (stock) + Clutch Plate (stock) + 5 spd Tx (Stck).
Researched and found the below post and details from JFP on torque specs: FW - 19ftlbs+120deg, Clutch plate - 17ftlbs. Thanks!
What about balancing? I have no tools for balancing... Should I be worried about it given I will be using my Warp 9 DC motor and not the engine?
Please advise. Thanks!
PorscheFan5 is offline   Reply With Quote
Old 07-08-2015, 03:23 PM   #18
Originally Posted by PorscheFan5 View Post
JFP and Team,
Porsche factory components are "somewhat" balanced, but probably not to the RPM levels the electric motor can turn. You might want to consider having an engine balancing shop true yours up.
Old 07-09-2015, 02:09 PM   #19
1999 base
Meir's Avatar
just for future reference.
final torque on DMFW should be 90 degrees and not 120.
in the 101 book there is a mistake that was copied from the Bentley book.
in the Bentley book it say 90 in one project and 120 in another.
this is from the shop manual.
Old 07-09-2015, 03:17 PM   #20
And for your reference, the was a later supplement to the Porsche service manual (a3050371, dated 2002) which reads:
"25 Nm(19 ft. lb.) plus 120 degrees."
That later data remains current according to Porsches electronic information system, PIWIS TSI.
