Old 12-12-2010, 04:16 PM   #21
edevlin's Avatar
Underdrive pully, Jake says its THE bolt-on that regularly makes HP that can be measured, and I put a lot of weight on what he says.
That being said, I have the Techno-torque and like it. I just not had the time, money and energy for an underdrive pully, but its at the top of my to do list,
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 12-12-2010, 07:36 PM   #22
Engine Surgeon
Cheapest and most effective bolt on that money can buy!
US Patent 8,992,089 &
US Patent 9,416,697
Old 12-12-2010, 09:07 PM   #23
Idaho Red Rocket 3's Avatar
Please explain what Techno Torque is.
Old 12-13-2010, 03:23 AM   #24
JTP
Red,
Techno Torque is a part made by Pedro and it replaces the "T" part of the intake plenum following the throttle body. The interior is modified to reduce turbulence created when incoming air hits the T pipe.
http://www.pedrosgarage.com/Site_2/TechnoTorque.html
JTP is offline   Reply With Quote
Old 12-13-2010, 04:23 AM   #25
To clear the CEL, you would have to reprogram the ecu in order for it to disregard the fact that the cats have been deleted. In my experiencing, going "catless" resulted in a significant loss of low end and mid range torque. Since the 2.5 engine only has one set of cats, you would be better off upgrading to a set of high quality lower cell units. This, however, can be an expen$$$$ive .
my ecu already has powerchip software,
so u don't recommend removing the cats? losing torque is the last thing i wanted to do,
dsisco is offline   Reply With Quote
Old 12-13-2010, 10:04 AM   #26
Johnny Danger's Avatar
I am not a scientist, nor do I play one on TV . Again, however, it was my experience that going "catless" resulted in a significant loss of low end to mid range torque by virtue of the fact that there was hardly any back pressure left in the system. The astute exhaust designer knows that you must balance flow capacity with velocity . In some cases, reducing velocity by means of an exhaust system that is too free flowing can greatly impact low end to mid range torque . This is better explained through the concept of how delta pressure works. I am sure that there is someone on the forum far more versed in this topic than me.
Old 12-13-2010, 10:18 AM   #27
JTP
Originally Posted by ronoroa.zoro8
Techno pair is a piece of Peter, which replaces the T after the throttle body intake plenum. The interior has been modified to reduce the turbulence created when the incoming air reaches the pipe T. The 2.5L engine has a unique set of cats, it is better to get a set of high quality units lower than the cell.
WTF? This is some weird combo of other people's replies and BS.
Old 12-13-2010, 10:21 AM   #28
This person also replied to my thread, "986 Turbo" ? I have no idea who they are, or what they were referring to ???
Old 12-16-2010, 09:06 PM   #29
update:
got my car back, installed new water pump, engine mount and LN thermostat,
my car feels like a different car!
highly reccomend the low temp thermo, car runs alot cooler, so i think the ecu runs more aggressive ignition timing.
problem i had was with the underdrive pulley, my mech says its totally wrong for my car, even with shaving down the boss
gonna take it to another guy for a 2nd opinion.
need to know if anyone has fitted the new style BBI pulley see picture
Old 12-17-2010, 07:17 AM   #30
Crazy Austrian
harryrcb's Avatar
[QUOTE=need to know if anyone has fitted the new style BBI pulley see picture[/QUOTE]
Yes I installed one, works great.. don't know what your guy reffered to other than the fact it's harder to hold when you tighten the bolt and does not have any TDC marks on it. Just keep your old pulley in case you ever need to do cam timing or install the LN eng IMS.
[IMG]smaller.jpg[/IMG]
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
Old 12-17-2010, 08:27 AM   #31
I am using the BBI pulley on my vehicle with no issues whatsoever. Tell your mechanic that he is far afield on this one .
JD
p.s. Its important to know, that a shorter belt is required to accommodate the smaller pulley.
Old 12-27-2010, 07:37 PM   #32
Has anyone noticed higher operating temperatures due to under-driving the water pump too? Or does the decreased load from spinning the other components at a slower speed make up for that? I don't think I've seen anyone discuss this.
1999 Boxster 3.4L
2007 BMW 328i
1992 Jeep Wrangler
BudmanV24 is offline   Reply With Quote
Old 12-28-2010, 09:05 AM   #33
Keith Newby's Avatar
I think previous posts stated that there was no increase in engine temp. attributed to the under drive pulley. Of greater interest to me was the mention of a power steering under drive pulley on the market. I may be wrong but I would think the power steering pump takes more power to run than the water pump...and as a person who would never grind away an engine boss, the more elegant steering bolt -on strikes a chord.
Keith Newby is offline   Reply With Quote
Old 12-28-2010, 09:14 AM   #34
Track rat
Topless's Avatar
Tests by Flat6 indicate that engine temps run lower with the UD pulley. I don't know if it is due to impeller cavitation at higher RPM with stock pulley, or just a better heat transfer flow match.
Old 08-04-2011, 08:46 AM   #35
Is this TechnoTorque product from Pedrosgarage safe to buy? What I mean is that the website looks fishy. No security in http(should be https) And he wants us to send him an email with all of our credit card info. I want the product but I don't feel safe buying it that way.
Any opinions?
Also, earlier in this thread someone mentioned getting the CEL from the fabspeed exhaust and secondary cat-bypass pipes. I emailed fabspeed and they insist that their bypass pipes and exhaust systems do not activate the CEL and that I should pass emissions testing with no problems.
Is everyone who installed the bypass pipes getting the CEL light?
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 08-04-2011, 09:29 AM   #36
ddb
www.klisstle.com
ddb's Avatar
Hi ProjectM96,
I ordered a TT2 from Pedro a couple of years ago without any issues. In fact, he sent me the TT2 and I mailed him a check later. He is a great guy and asset to the Boxster community. I don't think he has the https because there aren't credit card transactions on his site. At least not when I was on there the last time.
I don't have any experience with the Fabspeed system, but installed a complete system from another company without any CEL problems. I don't think installing secondary cat delete pipes and a muffler on a 2000 or newer will cause a CEL issue. If you install headers without the needed cats you will have an issue.
Best of luck,
ddb
Old 08-04-2011, 11:23 AM   #37
Any opinions?
Deleting the secondary cats will not cause a CEL. Also, Pedro has a very laid back and honest way of doing business . I purchased a TT2 from him a couple of years ago as well . And, like ddb he told me to simply mail him a check . No worries with Pedro . There should be more like him in the Porsche world .
Old 08-07-2011, 09:23 AM   #38
at the risk of sounding like the village idiot, can someone explain what an underdrive pulley does exactly? Do you lose/gain functionality of any other systems (AC, etc), and what is all involved with the installation?
-Village Idiot
stateofidleness is offline   Reply With Quote
Old 08-07-2011, 10:58 AM   #39
-Village Idiot
In layman's terms, by reducing rotational mass and under driving the vehicle's "accessories", the lighter weight pulley draws less power from the engine . No functionality is lost. However, some have reported that under extreme conditions when all of the vehicle's accessories (i.e. a/c , headlights, radio, wipers ect..) are being used at the same time, rpm's may fluctuate at idle . As far as installation is concerned, it's chicken scratch at first. However, once someone has done one - it's a breeze.
Old 10-15-2012, 08:09 PM   #40
What do you guys tus of this version of the underdrive pulley?
RSS Under Drive Pulley for Porsche Boxster, Cayman, Carrera, Targa
