Old 04-02-2010, 11:30 AM   #1
Talking Oil change procedure step by step
Porsche boxster oil change procedure
8mm wrench socket
Or t50 torx
Oil wrench 74/76 mm 14 flute
Step 1
Lift front left and place 2 pieces of wood under tire
Lift front right and place 2 pieces of wood under tire
Jack rear center at axel center****
Place stud left and right as well as 2 pieces of wood****
Leave rear center jack in place
You are now ready to work under the car
Put oil pan in place with large rim (spout) facing rear of car
Make sure oil is at 180 degrees Celcius
Loosen 8mm bolt****
Let oil drip for at least 15 minutes
Loosen filter housing using key wrench and oil cap wrench
Remove old filter
Replace filter and rubber seal
Tighten filter****
Tighten 8 mm bolt****
Fill oil 10 quart mobile 1 0W40
Tighten yellow oil cap
Lift center jack and remove studs from rear
LEAVE 1 (one) WOODEN PIECE UNDER REAR TIRE !!!
Lower center jack
You should now have the car on 1 piece in back.****
Jack up front left remove 1 piece
Jack up front right remove 1 piece
Drive car of pieces
Done!
Start car and check for leaks****
Done!
bartman is offline   Reply With Quote
Old 04-02-2010, 12:20 PM   #2
What are the **** for?
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
yimmy149 is offline   Reply With Quote
Old 04-02-2010, 04:56 PM   #3
stud = jack stand?
jlucas is offline   Reply With Quote
Old 04-02-2010, 05:26 PM   #4
Steve Tinker's Avatar
Loosen 8mm bolt****
Remove old filter
Tighten filter****
Sorry, but I would not follow this - if my oil was 180 deg C I would be worried, let alone getting it that hot for an oil change.
And I've never seen an M96 engine hold 10 quarts of oil - you would definately be overfilled.......
2001 MV Agusta F4.
Old 04-02-2010, 06:32 PM   #5
I see no mention of screaming as the 180C oil runs down your arm. No mention of bleeding as the 8mm Allen busts your knuckels. Cussing at the dog who keeps sniffing you. And the manatory cold Killian's for a job well done.
I did my oil change today, 9 quarts of 10w40 Castrol. NAPA filter.
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 04-03-2010, 06:47 AM   #6
tnoice's Avatar
ooohhhh, 10 quarts of oil is way too much. I usually only use 9 quarts and 1 extra quart will cause some issues.
Lov'n my boxster!
2013 Lexus IS350awd
2007 Toyota FJ Cruiser
2004 Porsche Boxster S
tnoice is offline   Reply With Quote
Old 04-03-2010, 06:53 AM   #7
jonnycool's Avatar
I thought step 1 was turn on the radio?....
jonnycool is offline   Reply With Quote
Old 04-03-2010, 06:56 AM   #8
jonnycool's Avatar
dick seems to fit! or any other four letter swear word....lol
Old 04-04-2010, 01:39 PM   #9
Nice post, but this belongs in the DIY forum I had a nice thread on this from last year but it looks like they delete older posts to save on memory space.
I use Pedros garage for a template on all my DIY projects
http://www.pedrosgarage.com/Site/DIY_Projects.html
A couple points of interest.
Tools needed: #8 long allen wrench(longer better for torque), "B" oil cap wrench (autozone), Napa gold filter part #7211, and 10 quarts of Castro syntec 10W40. Jack and jack stands are handy. You only need to jack up 1 side of the car. I did rear passenger.
napa gold filters are by far the best, and the general consensus is stay away from mobile 1 and without getting to expensive Castro Syntec has been the winner(general consensus from people smarter than me )
1.) If you live in a colder climate you might want to use 5W40 or 10W40(but get the 40). Warmer climates can get away with 0W
2.) I Removed the oil cap in trunk to help the flow. The oil will continue to drip out for up to an hour. If you jack your car up when you do it, make sure to lower it over the oil pan so it can drain completely. if you do drain it for an hour you will need about 9.5 quarts. Best to stop at 9 quarts and start the engine and then recheck(with the dipstick).
3.)Make sure your spout cover on your oil pan is open as it might overflow from the massive rush of "HOT"used oil. The oil does come out fast and can be damn hot!!
4.)Walmart takes back used oil for free(upto like 5 gallons at a time).
5.) My local oil change place let me pay them $10 and they used my filter and oil on my SUV(not my porsche). This can be an alternative to those who don't wanna get dirty!!
Projects completed:
1.) Serpentine belt...........$25 Gatorback w/ac
2.) Sparkplugs..................$42 Ngk-Ix-Iridium
3.) Radio replaced............$225 JVC HD50 (BB install)
4.) Tires............................$700 Sumitomo III Local shop
5.) Oil Change/air filter.....$94 catro syntec 10W40,napa gold,K&N air
6.) Speakers....................$143 Infinity Kappa F=4", R=6x4 plate
7.) Throttle body clean.....$5 Throttle body cleaner
8.) De-snorkel..................$.10 A few paper towels
9.) Alternator...................$221 Various Sockets
10.)Fuel filter...................$30 10mm socket and flat head screwdriver
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 04-04-2010, 03:21 PM   #10
Post by Bartman, as in Steve (the Cubs Killer)?
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
