Old 04-02-2010, 05:26 PM   #4
Steve Tinker
Steve Tinker's Avatar
Put oil pan in place with large rim (spout) facing rear of car
Make sure oil is at 180 degrees Celcius
Loosen 8mm bolt****
Let oil drip for at least 15 minutes
Loosen filter housing using key wrench and oil cap wrench
Remove old filter
Replace filter and rubber seal
Tighten filter****
Tighten 8 mm bolt****
Fill oil 10 quart mobile 1 0W40
Tighten yellow oil cap
Sorry, but I would not follow this - if my oil was 180 deg C I would be worried, let alone getting it that hot for an oil change.
And I've never seen an M96 engine hold 10 quarts of oil - you would definately be overfilled.......
2001 MV Agusta F4.
