Old 04-02-2010, 11:30 AM   #1
bartman
Talking Oil change procedure step by step
Porsche boxster oil change procedure
8mm wrench socket
Or t50 torx
Oil wrench 74/76 mm 14 flute
Step 1
Lift front left and place 2 pieces of wood under tire
Lift front right and place 2 pieces of wood under tire
Jack rear center at axel center****
Place stud left and right as well as 2 pieces of wood****
Leave rear center jack in place
You are now ready to work under the car
Put oil pan in place with large rim (spout) facing rear of car
Make sure oil is at 180 degrees Celcius
Loosen 8mm bolt****
Let oil drip for at least 15 minutes
Loosen filter housing using key wrench and oil cap wrench
Remove old filter
Replace filter and rubber seal
Tighten filter****
Tighten 8 mm bolt****
Fill oil 10 quart mobile 1 0W40
Tighten yellow oil cap
Lift center jack and remove studs from rear
LEAVE 1 (one) WOODEN PIECE UNDER REAR TIRE !!!
Lower center jack
You should now have the car on 1 piece in back.****
Jack up front left remove 1 piece
Jack up front right remove 1 piece
Drive car of pieces
Done!
Start car and check for leaks****
Done!
bartman is offline   Reply With Quote
