Old 06-19-2009, 09:03 AM   #1
damn oil leak...how bad is this?
where it coming from?
udontknowjack is offline   Reply With Quote
Old 06-19-2009, 12:27 PM   #2
is this the same youdontknowjack from mazda3forums?
LG Paul is offline   Reply With Quote
Old 06-19-2009, 07:09 PM   #3
Rear main seal.
2002 S
jhandy is offline   Reply With Quote
Old 06-19-2009, 08:21 PM   #4
so im one of the unlucky one huh?? 03 non s boxster with only 36k miles....rms and ims already??
Old 06-19-2009, 08:22 PM   #5
yes wassup paul....now im thinking i shouldnt got rid of my speed3 now i run into this expensive problem.....
Old 06-20-2009, 06:03 AM   #6
JAAY's Avatar
It is not that big of a deal if you can bring the thing to a lil indy shop or something. If you are good with tools the tranny is the easiest thing to get out. It takes me just about a half hour to get out. Good luck.
JAAY is offline   Reply With Quote
Old 06-20-2009, 08:19 AM   #7
To an "advanced DIYer" with the right special tools it is a "simple" job; even for the experienced DIYer this is no "simple" task, this requires special tools that you can't loan in just any shop. The RMS seal requires a special precision seating tool to put it in place although ive seen guys who just simply slap the new RMS in by approximation; IMO, i wouldn't take chances.
Most Indy shops would charge a standard labor 6-8hours for an RMS/Tranny job (6 hours is LUCKY). You are looking around $700-$1000 just for the RMS seal replacement alone, i suggest that you also throw in a new clutch to save you on labor costs...Time to raid the slush fund, GoodLuck
spine911 is offline   Reply With Quote
Old 06-20-2009, 03:21 PM   #8
well the first shop i call and quote me est $1350 rms parts and labor...if i do the ims at the same time will be est $1700 for both.....car need to stay over for a week...and hes a 3 week out for the next appointment...im looking around for another shop at the moment...
question...is it safe to drive around right now...or should i just leave it alone till this get look at and fix?? its my 3rd car so its no big deal if it need to be sit out for awhile...
Old 06-20-2009, 08:24 PM   #9
To defer RMS repair depends on the amount of the oil leak, make sure you check the oil levels regularly and add oil as needed. I managed to drive my 986 for almost 2 years with an active RMS leak.
I noticed you kept on mentioning IMS with this RMS leak, they are two DIFFERENT issues...There are no warning signs for an impending IMS failure/catastrophic engine failure...Jake Raby, as far as i know is the only one who has an IMS part "upgrade" kit available in North America...No one really knows the long term reliability of the IMS "upgrade"....What exactly will this mechanic do for this so called "IMS repair"????
Also, i remember from your previous posts that you have a Tip. FYI, an RMS leak is quite RARE in Tips due to the difference in designs...Bring your car to a reputable mechanic who will repair/diagnose this car properly.
Old 06-20-2009, 08:30 PM   #10
thats exactly what a local shop guy tells me....where else could this oil leak from?
Old 06-20-2009, 08:36 PM   #11
From your pics it definitely looks like an RMS leak (oil from center tranny bell housing), RMS leaks in Tips are rare but not impossible.
I am a little skeptical about the "IMS repair" part.
Old 06-20-2009, 09:18 PM   #12
so ims doesnt seem to be needed?
Old 06-20-2009, 09:31 PM   #13
I personally wont touch the IMS.
Focus on the RMS leak, also try to look at other possible common sources of leaks (Spark Plug tubes, Cam/Valve cover gasket, AOS)- if all these are dry, it is quite definite to be RMS...Shop around for a shop who will give you a good price.
Old 06-23-2009, 02:32 PM   #14
The leak could also be from the IMS bolts. They are located above (or below, can’t recall) the RMS and are usually replaced when the RMS is replaced as a precaution. Porsche has an updated "encapsulated" bolt(s) that supersedes the original bolts. This is not to be confused with the updated IMS bearing from Raby/flat6.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 06-25-2009, 11:39 AM   #15
tonycarreon's Avatar
01 boxster tip, RMS replaced DEC '08
Old 06-25-2009, 01:43 PM   #16
It's more than likely an RMS leak. If it's just a minor leak with a few drops on the floor then I wouldn't change it out right away. Wait until you need a new clutch and then have the RMS swapped out then. Just put a piece of cardboard down in your garage in the meantime.
'03 3.2L GuardsRed/Blk/Blk---6Spd
Options: Litronics, 18" Carrera lights, Bose sound, Painted to match roll bars.
http://i100.photobucket.com/albums/m...Mautocross.jpg
Adam is offline   Reply With Quote
Old 06-25-2009, 04:54 PM   #17
already talked with a few shop...since its a tip and only a few drop on the driveway....its not gonna hurt the clutch or anything...only need to change it when i cant stand the oil drop on my driveway....i can live with that....
Old 06-25-2009, 06:18 PM   #18
Oh, since you have a tip scratch what I said about the clutch job. If you can live with a small oil leak then you're ok, but it sucks getting oil all over your driveway and you can't lay down cardboard there to easily.
Old 06-25-2009, 06:24 PM   #19
Just as i previously mentioned, you can defer the RMS repair depending on the amount of the oil leak, make sure you check your oil levels regularly.
Old 06-25-2009, 08:37 PM   #20
for $1300 the cost to replace rms....i can get a truck load of this
http://www.jnkproducts.com/pour-n-restore.htm
