Old 08-22-2017, 07:12 PM   #1
short shift kits, yes/no?
hey
I'm considering a short shift kit for my 2000s. Any recommendations, pro, or con?
Thx
boxsterboxster is offline   Reply With Quote
Old 08-22-2017, 07:20 PM   #2
911monty's Avatar
I upgraded my original to a B&M short shifter. Absolutely love it compared to the stock vague shifter. However for the price I don't believe you can do better than Ben's or Particlewave's kit. In fact if mine was showing any signs of wear I would buy one!
Old 08-23-2017, 02:59 AM   #3
Ben-Auto-Design
Ben006's Avatar
There is no drawback with a short shifter! It's all benefits
Porsche Tech in France.
www.benautodesign.fr
1982 928 S Euro
Ben006 is offline   Reply With Quote
Old 08-23-2017, 04:04 AM   #4
jsceash's Avatar
It's one of the best all round upgrades you can make. Track or street use.
Old 08-24-2017, 05:40 PM   #5
Short shifter pro: you won't need to move your shift knob as far. (obviously!)
Short shifter con: you will need to apply a higher amount of force with your hand to the knob to get it to shift.
There are many variants of short shifter, FYI, some of which are factory and some of which are aftermarket, and a range of throw reductions are offered. The throw reduction front-back can be different than the throw reduction side-to-side. One inescapable fact of physics of the levers involved is that the more the throw is reduced by changing the basic lever geometry, the more the force will be required to accomplish the shift. It's simple physics! If a little bit of good, more is not necessarily better.
It's also subjective. Something more important than reducing the throws, in my opinion, is to reduce friction and slop in the system. This is about more than just the shift console - cables running underneath the car, the various linkages and bellcrank mechanisms (both below the shift lever and back at the transmission), and even internal condition of the transmission's shift forks, springs, bearings, and fluid, can all factor into the shifter's performance.
Hope this helps give you some food for thought. Cheers!
2001 Boxster
Old 08-24-2017, 06:15 PM   #6
steved0x's Avatar
I have one of Ben's, love it! Before that I had a 9x7 shifter, 15% shorter than stock, loved it too. Didn't really like the original shifter but didn't hate it.
Old 08-24-2017, 08:55 PM   #7
Thanks for the input, very helpful as usual.
Old 08-27-2017, 03:01 PM   #8
IMHO this is a total no-brainer. The original shifter was like rowing a boat. I put in the 9x7 short shifter and have never looked back. The shift effort was up but it took little time to get used to it and I could never imaging going back.
Old 08-27-2017, 09:44 PM   #9
I just installed a $50 eBay short shift this weekend. Love it to bits.
The extra effort required to shift IMHO is not an issue. It helps me shift more positively and now at last I can shift quickly. The heavier feel matches the relatively heavy clutch and steering and therefore feels right in the car. In retrospect, the stock one didn't gel with the rest of the car.
Hagu13 is offline   Reply With Quote
Old 09-09-2017, 04:55 PM   #10
Artist, 986S tinkerer
NewArt's Avatar
I have Ben's shifter and I'm still not happy with the shifting of my car. I don't think it's really the problem with the shifter but I think I have rather a problem with the cables, which are quite stiff. I need 2 hands to put it into reverse! (At least it won't be put into reverse unintentially!) I'm going to try some other guys shifters next week at the track to compare.
Old 09-10-2017, 04:58 AM   #11
steved0x's Avatar
Take off the boot and look under there while shifting into reverse and check to see if the ball end of the fore/aft cable is hitting the right side of the console. My original shifter ends were misaligned and was doing that and it was very hard to get into reverse.
Old 09-10-2017, 11:16 AM   #12
Ben-Auto-Design
Ben006's Avatar
Yes, misadjusted cables can cause hard shifting!
Look at your cables end at the transmission too.
1982 928 S Euro
Old 09-11-2017, 06:57 AM   #13
Racer Boy
Racer Boy's Avatar
I just installed a short shifter that I got from Particleweave, and I'm not yet used to it. The throws are REALLY short, and it will just take a bit of adjustment before it (hopefully) feels normal. I haven't missed any shifts, but I rarely rush them anyway.
The shift action does have a nice heft to it, and the mechanical feel is also pretty nice.
Hopefully I'll be attending a track day this Wednesday, so it'll be interesting to see how that goes.
Old 09-13-2017, 09:57 AM   #14
Pathological Tinkerer
I have one from Ben and love it. It totally transforms the driving experience. I installed mine while it was down for three months so I didn't have such a jarring difference from before and after to get used to.
P_Carfahrer is offline   Reply With Quote
Old 09-14-2017, 03:27 AM   #15
NewArt, make sure it's not rubbing against the carpet below it. I put washers under the shifter assembly to raise it off the carpet.
Old 09-22-2017, 09:02 AM   #16
Filastein's Avatar
Simple... Get it. It's what should have been on the car in the first place.
2 0 0 1 S
Filastein is offline   Reply With Quote
Old 09-22-2017, 10:17 AM   #17
01101
Is there a guide for adjusting these, or is it pretty straight forward? I think mine is in need - damn near throwing my shoulder out on 5-6.
alm001 is offline   Reply With Quote
Old 09-22-2017, 04:06 PM   #18
After 1-yr ownership, yet to convince me that I need a short shifter. Came from 914 with a vague shifter, so the original feels super tight and precise in comparison! Throw can be a bit shorter but load feels just right as is.
Old 09-22-2017, 06:40 PM   #19
Coming from a 914, anything might feel ok!
My first test drive in a Boxster was a really nice, low mile '99 back in 2004. My previous cars had been a Miata, a '99 Z3. I loved the Boxster except the shifting felt so sloppy and vague I thought that there was something wrong. It stuck with me and I later found, through reading and driving other Boxsters, that my experience was the norm.
When I finally bought my car in 2008, I enjoyed everything about the car and got use to the shifter. A few years ago, my boys bought me a short shifter for Christmas . After install, I was amazed at the difference and how much 'newer' my car felt.
Heck of an upgrade!
Old 09-23-2017, 11:27 AM   #20
Chuck W.'s Avatar
I put a Numeric Shift Console and Numeric Cables. Very costly but a dramatic difference in shift throws and the feel.
1995 Porsche C4 Cab
