Old 10-23-2017, 01:17 PM   #1
Recommend
I just had a B&M 45135 installed on my '00 Boxster S—first reaction: WOW, this is how it was meant to be driven!
square-root is offline   Reply With Quote
Old 10-23-2017, 02:38 PM   #2
jaykay's Avatar
I have a B+M for sale....already mounted. It should still be in the for sale section.
986 00S
Old 09-23-2017, 12:27 PM   #3
Chuck W.'s Avatar
I put a Numeric Shift Console and Numeric Cables. Very costly but a dramatic difference in shift throws and the feel.
1995 Porsche C4 Cab
Old 10-24-2017, 11:13 AM   #4
WALDMEISTER
BRAN's Avatar
I'm gonna get the Factory short shifter kit on Thursday...my P-service guy had to dig deep into the system to find one...lol
Can check mark that one on my to-do list
Old 10-25-2017, 01:24 PM   #5
Ciao's Avatar
Interesting. I did not know there was such a thing. Where can you get a "factory short shifter kit"? I'm thinking going factory as much as possible leaves less collateral damage in terms of post-functional performance
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 10-24-2017, 11:36 PM   #6
987 shifter and knob in mine, far better than stock.
That986 is offline   Reply With Quote
Old 10-25-2017, 12:06 AM   #7
fridsten's Avatar
Damn! Now you guys got me looking for a 9X7 shifter... :P
fridsten is offline   Reply With Quote
Old 10-26-2017, 12:43 AM   #8
Probably the best mod i've done to my car. Far more positive action, just feels like it should.
Old 10-25-2017, 06:52 AM   #9
On the slippery slope
JayG's Avatar
The 9x7 shifter is a little shorter than the stock 9x6 shifter and works well
2004 996 Targa Tip
Instructor - San Diego region
Old 10-25-2017, 11:10 PM   #10
When someone says "factory short shifter" in the context of a 986 Boxster there are actually at least four different parts they may be referring to.
The picture shows three of them:
1. On left we have the standard 9x7 shift console, a factory Porsche part which reduces the front-to-back and side-to-side throws by about 15% vs the 986 shifter. Note the black plastic middle piece, and steel part that bolts to the side. (This is white plastic on the 9x6 shift console.)
2. At middle in the picture, we have the 997GT3.2 factory shift console (not Tequipment or aftermarket). It has the same geometry (and throw reduction) as the standard 9x7 console, but replaces the "rubbery" feeling, (and prone enough to wear that by about 100k miles, they will almost certainly be "shot") hard plastic+polyurethane bushings with tighter, and longer-lasting solid metal bushings. You won't be able to shift in a straight line diagonally across gates anymore like you can do with the more rubbery plastic+polyurethane bushings, so it feels different.
3. At right in the picture above, we have one of two different "genuine Porsche aftermarket" Tequipment short shifter kits which Porsche has sold aftermarket as replacement "upgrade" part. Note the blue plastic piece, substituting for the black plastic piece of the 9x7 shift console. This provides the exact same side-to-side throw as the 9x7 shifter, but reduces the front-to-rear throw significantly more than the 9x7. It has the same plastic and polyurethane bushings as the factory 9x6 console and standard 9x7 console.
Supposedly Porsche offered at least one other Tequipment aftermarket short shift kit, and the one linked to below seems to be what most inexpensive, generic aftermarket "short shifters" are attempting to copy:
Porsche Short Shifter - PelicanParts.com.
This has more aggressive throw reduction than the 9x7 console, although I'm sure exactly how it compares to the blue plastic tequipment version. I think both of the aftermarket Tequipment consoles are the most aggressive in front-rear throw reduction than any factory (non-aftermarket) options.
Hope the info helps. Best of luck!
2001 Boxster
Old 10-26-2017, 09:41 AM   #11
WALDMEISTER
BRAN's Avatar
The "factory kits" the P-service guy found were:
997 424 983 00 ( for > MY04 / 987 upwards) -- Tequipment I think
and 000 044 700 26 -- I will see what they finally installed in mine
Old 10-27-2017, 10:03 AM   #12
WALDMEISTER
BRAN's Avatar
HALLELUJAH...what a difference!
This was money well invested. So precise, so short, so fast, ... snapping into gears...just wow.
Lets the stock shifter appear like from a 1972 VW Beetle
Old 11-12-2017, 04:33 AM   #13
Ben-Auto-Design
Ben006's Avatar
Factory Porsche short shifter! Nice!
Just to let you guys know, I'm back in the game!
I have plenty of shifter that will be ready before next weekend, no pre-order this time
Ben
ASE certified Automotive Master Technician.
Porsche Tech in France.
www.benautodesign.fr
Ben-Auto-Design : Performance parts for 9X6 / 9X7
1982 928 S Euro
Ben006 is offline   Reply With Quote
