Old 01-29-2017, 01:02 PM   #1
MAF sensor R&R what size Torx ?
I did a search on this site and on Google . General consensus is that it is a T20 security Torx but some say it is a 5 star ( vs. 6 star ) security Torx . My 6 star T20 security Torx does NOT fit the screws . I tried grabbing with pliers , vice grips , jamming screwdrivers etc. and neither one will budge . I have no problem buying the correct tool just need to know what that is . To my eye the screws have 5 points but it's difficult to get a good viewing angle . If anyone has the tool part number that would be great . Looks like bit is the best way to go .
rfuerst911sc is online now   Reply With Quote
Old 01-29-2017, 01:32 PM   #2
Screw it ( pun intended ) I just ordered a set of 5 star security Torx bits will have by end of week . Once I get the MAF sensor out I will throw those Torx screws as far as I can !!! Stupid fuc#@%&*ing design !!! Will replace with standard hex head .
Old 01-30-2017, 12:39 PM   #3
jb92563's Avatar
I had a set of 20 security bits from Harbor Freight and the one size in there fit the MAF.
Throw that security bolt and the one on the transmission case as well over the Falls in Niagara.
Annoying!
Old 01-30-2017, 01:03 PM   #4
Be careful when you remove the MAF.It is delicate.
Make sure the upstream screen is still intact and not blocked with debris.
Old 02-04-2017, 09:12 AM   #5
I received the 5 star security Torx bits in the mail so this morning I went about removing/replacing the MAF sensor. It took a whopping 30 seconds to do with the right tools As it turns out the screw size on mine was TS25 I only mention that because I found many posts that stated it was T20 . Anyway that job is now done .
Old 02-15-2017, 06:20 PM   #6
Lew
So Blessed!
Lew's Avatar
I pulled out my MAF today to check if it needed cleaning. Not bad for 30k! I agree the security torx screws can be a pain, and to reach. I used the proper security bit which was installed in a 3" magnetic extension, and the extension was fit into a small socket with a 8" inch extension. I had to wrap tape around the magnetic extension where it was inserted into the 1/4" socket. Things just would not stay together. I might add, when the screws were completely loose, I used a telescoping magnet that I placed on the head of the screws to keep from loosing. The MAF is somewhat hard to get to and it's a tight area, plus the wiring connector is hard to remove. I pulled the MAF without removing the wiring connector. The connector is easier to remove once the MAF is removed. Anyway all work out OK.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
