Old 02-15-2017, 06:20 PM   #6
Lew
So Blessed!
Lew's Avatar
I pulled out my MAF today to check if it needed cleaning. Not bad for 30k! I agree the security torx screws can be a pain, and to reach. I used the proper security bit which was installed in a 3" magnetic extension, and the extension was fit into a small socket with a 8" inch extension. I had to wrap tape around the magnetic extension where it was inserted into the 1/4" socket. Things just would not stay together. I might add, when the screws were completely loose, I used a telescoping magnet that I placed on the head of the screws to keep from loosing. The MAF is somewhat hard to get to and it's a tight area, plus the wiring connector is hard to remove. I pulled the MAF without removing the wiring connector. The connector is easier to remove once the MAF is removed. Anyway all work out OK.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
