Old 06-25-2015, 11:44 AM   #581
amagalla's Avatar
I started the install process of the wind stop.
I just need to wire it up now. I can say that the lower Boxster S logo does not get in the way of the rear view at all. Fantastic.
Glad to hear JJ is doing better. Thanks Fred.
Tony
Lapis Blue 03 Boxster S
Old 06-30-2015, 05:12 AM   #582
The wife and kid are at the in laws for a couple days so daddy got to play with his toys for a little. Installed new LED side markers and the wind breaker finally,wired it to the ash tray light:
I should add, the entire install including wiring took no more than 30 mins, probably less actually, I even drilled a channel in the trim to route the wire through. The only thing I had some trouble with was taking the existing piece off without snapping the latches, I was pulling upwards instead of back of course.
Thanks Fred!
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 06-30-2015, 08:17 AM   #583
Nine8Six's Avatar
Tony, Amit, looking cool guys and welcome! That cold white looks class
I also got mine installed only this last Sunday afternoon, forever red! Love the new coated panel... I can actually wash it without having to polish it after lollll
Dunno about you guys but I had a massive static issue with mine right after install but that seem to be completely gone now. It discharged itself after a few hours of driving thankfully. So if you experience the same, put it on and drive drive drive, and drive!!!
Old 06-30-2015, 08:03 PM   #584
Toppy
Toppy986's Avatar
Looking like mine has just cleared customs, any one who has already installed would you care to share some pictures on the wiring?
1999 Boxster
Arena Red/Graphite Grey Interior/Black 03 Top/550 All Red Tail Lights
Toppy986 is offline   Reply With Quote
Old 06-30-2015, 09:53 PM   #585
Fintro11's Avatar
Look further back I posted pics of wiring install
Fintro11 is online now   Reply With Quote
Old 07-01-2015, 05:52 AM   #586
BruceH's Avatar
I have some pics somewhere also. I ran my wire along the driver's side door sill to a fuse tap. I mounted the rheostat next to the document holder under the steering wheel.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 07-01-2015, 08:52 AM   #587
BruceH's Avatar
Here are a couple of pictures from my install.
You can barely see the wire heading under the sill.
DEPO Tail Lights
Old 07-01-2015, 12:55 PM   #588
kjc2050's Avatar
Test Photo
A shot of my Skybreaker taken in my garage. I've thought all along that I'd try to shoot it at dusk (in a less cluttered environment!), but now I think doing it near dawn when the light is diffused might work better. Sorry this has taken so long, Fred, but it's a bit of a bugger to shoot. The Porsche crest needs to have a darker background behind it, of course. Also, I didn't bother cleaning it before taking this image, so need to tend to that when I try shooting it outside. Only other comment - when I "turn up the volume" full blast, there's a lot of visual static in the deflector itself. Not sure that'd be the case with the blue or red ones.
Old 07-01-2015, 08:08 PM   #589
jaykay's Avatar
Is there a more convenient source of power where- by you could locate the rheostat at the roll bar firewall area and avoid visible wires?
Defrost hard window or speaker box power?
986 00S
Old 07-02-2015, 04:21 AM   #590
kjc2050's Avatar
Wow. Will keep trying...
Shot at dawn. Ran into issues with depth of field/focus. Aaaaarrggghh!
Old 07-02-2015, 09:23 AM   #591
Fintro11's Avatar
This is how I did mine,
Originally Posted by Fintro11 View Post
How I installed My Windstop
Step One -
Carefully push the windstop clip and pull the windstop towards the back of the car. The wind stop should pop out easily and without much force. ( Take care not to break the clips )
Step Two -
Once you have your windstop out pull the bracket away from the screen. The bracket should come away relatively easily.
Step Three -
Line up your illuminated windstop to the bracket. You will have to drill a small hole for the cable to run though. I used a small drill bit and drilled from the top down, then from the bottom up applying pressure along a horizontal path ( so the connector can slide past )
Step Four -
Install your illuminated windstop into the bracket and install it onto your car. You will want to keep the protective sheet on the windstop for now. Make sure the wire runs towards the driver side. I used a large flat screwdriver with paper towel wrapped around the tip and pushed the wire into the gap on the roll bar cover.
Then keep running it around the back of the seat
Step Five
Run the wire into the seam of the access panel down leading to the arm rest cubby
I removed the ash tray, and the ash tray housing to access the ash tray light circuit.
I fed the power cable up underneath the parking brake. Once I had the wire where i wanted it, I tucked the wire up inside the console ( see the above picture )
As per the image above I soldered the wires into the ash tray circuit. Once done I wrapped with electrical tape and re installed the ash tray.
Sorry for any mistakes and Fred/ Charles please add in if i did anything wrong!
Hopefully this helps as a reference for you guys.
PS Fred thanks for making such an amazing product!
Old 07-03-2015, 06:50 AM   #592
Fintro11's Avatar
Just installed the new one
Old 07-03-2015, 06:56 AM   #593
BruceH's Avatar
I installed mine the other day too. Version 1.0 rattled quite a bit at speed, Ver 2.0 is significantly better! Thanks again Fred
DEPO Tail Lights
Old 07-03-2015, 02:34 PM   #594
Toppy
Toppy986's Avatar
Canada Post delivered today, know what I am doing this week-end
1999 Boxster
Old 07-03-2015, 08:11 PM   #595
Was pleasantly surprised by the arrival of my windscreen in today's mail (I didn't think we were getting mail today because of the Fourth of July Holiday being observed today)...
Took longer to remove the broken clip (the stub was stuck in the hole where it snapped off) than it did to do the actual install. And I think it looks pretty damn awesome
soxfan1966 is offline   Reply With Quote
Old 07-04-2015, 06:44 AM   #596
kjc2050's Avatar
Old 07-04-2015, 11:41 AM   #597
Toppy
Toppy986's Avatar
Installed this morning, wired to ash tray light, thanks Fred for your excellent work, I love it
1999 Boxster
Old 07-04-2015, 01:50 PM   #598
Rookie
Ordered the crest with Porsche in amber with the cool white option, cant wait! Very very cool, you the man Fred.
02 Seal Grey 5 Speed
TypeA is offline   Reply With Quote
Old 07-06-2015, 05:07 AM   #599
Looks good... How did you get the adjustment know inside the cubby like that? I also wired mine to the ashtray light and fed the wire for that up under the trim but I have the adjustment knob just hanging over the side of the cubby which I do not like...
Old 07-06-2015, 12:45 PM   #600
Toppy
Toppy986's Avatar
I pulled off the side panel on the console, drilled a small hole into the cubby, guessing at bottom height. Fed both wires through the hole. Fed the feed wire behind park brake trim into the ashtray area. Cut feed wire at length for ashtray light, and after the white end was connected, coiled up extra wire and stuffed it behind the seat belt post carpet.
1999 Boxster
