Old 02-01-2015, 03:23 AM   #381
JonD's Avatar
Nice Fintro,
How about this on the screen? This will stir the purists hehehe
1998 Porsche Boxster
986 Arena Red, Tiptronic Base
JonD is offline   Reply With Quote
Old 02-02-2015, 05:42 PM   #382
Beginner
Jamesp's Avatar
You won't need to adjust the intensity quite often.
After one days driving I beg to differ. This is a toy within a toy and needs to be continuously adjusted. Full intensity for top down city driving at dusk, medium intensity after that, lowest intensity with the top up, and off for night time top up long distance driving. At least that's me, other's mileage may differ.
2003 S manual
Old 02-02-2015, 06:40 PM   #383
Nine8Six's Avatar
Just recalled you've got the cold white. Yea these are pretty sexy and can be cranked a bit without being seen from space. The RED however needs to be left at 5% at all time I'm afraid.
LOL you remind me of my mate here who drives a 987. We've airbrushed his deflector with PORSCHE using phosphorescent pigments (0 volt!). He told me "man every time I see a SUV, a van or a truck in my rear mirror I just pull in front of him so that his headlights can recharge the pigments for 10-20secs"
At first I went 'hahaha' and then his GF goes; he is serious, some guy was beeping at us yesterday because we were blocking his way LOL
All good fun!
SkyGlow: Here some one+ month old R&D lollll Looks okay, nothing like the SkyBreaker tho... no edge lighting :/ Takes about 10secs to charge up but discharge within 20-30min
Old 02-03-2015, 08:26 AM   #384
Fintro11's Avatar
Hey Fred, will you paint my whole car? Lol
Old 02-03-2015, 01:22 PM   #385
On the slippery slope
JayG's Avatar
you evil genius, definitely have too much time on your hands
2004 996 Targa Tip
Instructor - San Diego region
Old 02-03-2015, 04:10 PM   #386
There Is No Substitute.
rick3000's Avatar
Just started playing with my new windscreen and a 9V battery. It is very, very cool! I may swap out the white LED for blue before I install it. Unfortunately, I am waiting for it to get warmer and my hardtop to come off before I wire it up. I also need to find another plastic frame for the plexiglass, mine is starting to break.
As always, exquisite work by Fred.
The photo doesn't do it justice, and it still has contact paper on the back:
Old 02-03-2015, 05:08 PM   #387
Nine8Six's Avatar
aha - not too much time Jay, quite the opposite. This came to mind when I was being harassed by my mate here, asking for his SkyBreaker, every day almost. Didn't had much time to prototype the 987 kit, etc etc. Told him: just drop by and I'll give you a temp solution. We'll do his 987 SkyBreaker kit later this spring
lol Firefly Boxster!!! I'll start with my bike and see how it goes (wish I'd be serious)
Old 02-03-2015, 06:13 PM   #388
JayG's Avatar
Fair enough, still an evil genius
2004 996 Targa Tip
Old 02-04-2015, 11:16 PM   #389
JonD's Avatar
False alarm sorry
Old 02-04-2015, 11:52 PM   #390
hemonu's Avatar
@JonD:
I had the same problem. But it was a matter of the right pulling force. I pulled quite hard at both upper ends of the frame and one end moved a bit. From that it was possible to go on all around the window.
Herbert
hemonu is offline   Reply With Quote
Old 02-05-2015, 12:13 AM   #391
JonD's Avatar
Originally Posted by hemonu View Post
@JonD:
Herbert
Herbert since you saw what I wrote before. There's actually a VERY simple no force way to remove the Perspex, In fact NO effort at all.
Get a flat screw driver one that fits between the Perspex and the frame (there's a tiny gap at the TOP of the frame). Lever it a little and gently pulling towards the frame the Perspex tab just pops out away from the frame then it just comes out.
Really simple and no effort actually
Old 02-05-2015, 05:47 AM   #392
Nine8Six's Avatar
Nice one Jon, good visual thx man. Looks too easy lolll
Old 02-05-2015, 03:39 PM   #393
Fintro11's Avatar
all i had to do is pull the frame away from the windstop, did not take any force at all
Old 02-05-2015, 04:47 PM   #394
kjc2050's Avatar
Same thing here.
Old 02-05-2015, 09:01 PM   #395
JonD's Avatar
Thanks Fred glad I could contribute something at least. The pic is someone else's (Fintro) can't take credit for that, I just added the down arrow and the writing
I think some people may be able to pull the frame away easily, unfortunately mine was stuck like it was glued in, I nearly gave up trying and was going to see if I could buy another frame, as a last resort I tried the screw driver and was amazed how easily it popped out So I thought I'd share in case someone else experiences the same problem as I did.
Cheers
Who was it that said "Give me a long enough lever and I will move the Earth"? Hint he was Greek
Old 02-06-2015, 01:07 PM   #396
BruceH's Avatar
What do the experts think about using a fuse tap? Ideas on which circuit to use? I want to run the wire to the driver foot well and then locate the switch next to the document holder under the steering wheel.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 02-06-2015, 03:25 PM   #397
Beginner
Jamesp's Avatar
I like the idea of the LEDs coming on when I turn on the headlights.
2003 S manual
Old 02-06-2015, 03:44 PM   #398
amagalla's Avatar
I personally like the idea of the LEDs coming on with the parking lights.
Lapis Blue 03 Boxster S
Old 02-06-2015, 04:03 PM   #399
Fintro11's Avatar
Having it on the ash tray, the skybreaker turns on as soon as you turn the light switch to parking lights or headlights
Old 02-06-2015, 04:16 PM   #400
BruceH's Avatar
I ended up tapping into fuse E1 which should be the radio according to my diagram. There is a hole just above the fuse panel that I put a bolt in to use as the ground. I found that tidbit on the forum when someone hard wired their radar detector. I ran the wire under the sill plate. Very impressed with the light itself. Be careful cleaning though. I used a microfiber cloth that actually caused some very slight scratches I was able to polish them out with some Plastix.
I put the control next to the document holder with some Velcro.
DEPO Tail Lights
