Old 06-13-2014, 08:54 PM   #1
On the slippery slope
JayG's Avatar
upgrading dash speakers
I just finished upgrading my dash speakers from the factory ones. I have the basic sound system, no Bose, no door speakers, no rear speakers, and no amp. My factory speakers were very basic, no separate tweeter or even a wizzer cone
The factory speakers leave a bit to be desired, so they had to be changed out.
My new speakers sound so much better!
I saw in several threads that there were some adapter plates available, I could not find them and I did not want to destroy the factory speakers to mount the new ones so I made some.
I used 3/16" Lexan. I went to a local plastic store and found a piece of scrap 6" x 24". They charge $1.00 per pound, but went I went to pay, they just gave it to me!
I cut out the plates with a rotozip and then used my angle grinder to smooth and adjust for final fit. You also need to grind off the mounting tabs on the speakers. I found the speaker adapter wire with the correct connector at Crutchfield for $10.
I used silicon caulk to "glue" the speakers to the plates
I have a template for the adapter plate, so if you are interested, PM me and I'll email it to you
This is the first part of my full system upgrade. I plan to change out the head for a Parrot Asteroid Smart, add an amp, add rear speakers and a sub-woofer. I found a powered sub-woofer that almost fits below the right seat, just have to figure out how to raise the seat tracks about 3/4"
Ill post additional pics, etc as I progress
This is the factory speakers
Adapter plates
front and back views
New speaker mounted with adapter plate and speaker connector
2004 996 Targa Tip
Instructor - San Diego region
Old 06-13-2014, 09:00 PM   #2
Looks nice.
Old 08-25-2015, 08:05 AM   #3
WALDMEISTER
BRAN's Avatar
I did my upgrade last weekend.
From: Basic sound system, no door speakers, no rear speakers, factory speakers without tweeters.
To: Infinity Referenz 4002cfx Series 2
I used the old speakers to create mounting devices/gaskets. Pretty easy with a Dremel. Although the right speaker side seemed pretty tight, with little adjustments the new speaker sat flash after all.
WHAT A SOUND DIFFERENCE!
The HAES speakers went directly in the garbage!
50 bucks well invested! Now an active mini subwoofer is on the way...
Old 08-25-2015, 08:32 AM   #4
JayG's Avatar
Add rear speakers, they make the most difference
What sub are you getting and where will it mount?
2004 996 Targa Tip
Old 08-25-2015, 09:48 AM   #5
WALDMEISTER
BRAN's Avatar
Kenwood KSC-SW11 active subwoofer (11 x 7.5 x 2.8 inches)
--> it should fit under the passenger seat, we'll see...
Old 08-25-2015, 09:57 AM   #6
I got those Infinity speakers last year too. Sounds great. I also cut out the old speakers to put the new ones in. The driver side took some effort to shove the speaker assembly back in the hole, but it finally went it.
hancock1701 is offline   Reply With Quote
Old 08-25-2015, 10:09 AM   #7
Giller's Avatar
Sound can be very subjective, but IMO these cars have a great cockpit for sound and even just upgrading the doors (as I did) or the dash can have a huge impact.
I put in a couple of nice Focals in the doors and upgraded the head unit. Huge huge improvement.
Can be costly though. The adapter alone for the head unit was over $300 (plus shipping and exchange for us Canucks). Ouch.
Old 08-25-2015, 11:01 AM   #8
JayG's Avatar
I have been looking at that one. Just not sure if it fits
Someone has also tried a sub from a Subaru legacy
Here is another option, only 2.4" thick
http://www.amazon.com/PIONEER-TS-WH500A-HVT-Sealed-150-Watt-Subwoofer/dp/B00QNSZUOY/ref=pd_sim_sbs_422_9?ie=UTF8&refRID=0WF486WG17CZ3N0RWHZ0
2004 996 Targa Tip
Old 08-25-2015, 11:27 AM   #9
EJ-Fresno's Avatar
Is it possible to install a subwoofer on a stock 6-way amp?
Or you need an aftermarket HU?
Thanks.
2003 2.7 Boxster - Tiptronic - Carrera wheels - OBC - Red calipers - Cat pipes - Modified muffler - Rear speakers - K&N - Litronics
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 08-25-2015, 12:04 PM   #10
amagalla's Avatar
The speakers in the doors on the Hi-Fi optioned systems are subwoofers (although not very good ones).
Lapis Blue 03 Boxster S
Old 08-25-2015, 02:14 PM   #11
EJ-Fresno's Avatar
Yes, I replaced those with Polk speakers but it is still not that good... Maybe I should have put small subs?
2006 V6 Mustang
2008 ML 350
Old 08-25-2015, 02:21 PM   #12
The problem is the weak stock amp. Most after market head units put out more power.
Old 08-25-2015, 05:55 PM   #13
Beginner
Jamesp's Avatar
I put in 3 1/2 infinity reference and ran the stock amp. Mediocre at best. Just bumped that to 80W per channel with a new double din unit and the infinities rock. Upgrading with more Infinities, a couple of thousand watts and a sub soon.
2003 S manual
Old 08-25-2015, 06:25 PM   #14
lkchris's Avatar
Add rear speakers, they make the most difference.
They are good for sure.
Interesting thing when you have M490 (door subwoofers and amp) is that the amp has inputs for rear speakers but no output connection. For this, just find a 6x40 amp from a 996 to replace your 4x40 and insert the pins of the rear speaker harness in the empty spots in the output connector and you're good to go. 996 amp is same physical size, fits existing bracket, and existing harnesses connect right up. A little modding of output connector is required but pins stay the same.
996 amps come in coupe and cabrio versions. First one I tried was coupe and I was underwhelmed. A cabrio version made a significant difference, so much so that it's as if it's the first time I've actually heard my door speakers sounding like subwoofers.
This is as far as I'm going for now, as the radio is inaudible at highway speeds and will see if next tire set improves that enough to consider more stereo power. Maybe some dynamat in doors.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 08-25-2015, 07:31 PM   #15
JayG's Avatar
You must have some really noisy tires
I can hear my stereo really well on the freeway and I just have a CDR-23, dash and rear speakers no amp, no sub
2004 996 Targa Tip
Old 08-26-2015, 12:24 AM   #16
amagalla's Avatar
This is what I did:
Complete Audio Upgrade (plus adding a garage door opener)
Old 08-26-2015, 08:12 AM   #17
EJ-Fresno's Avatar
Agree, I can hear pretty good even at high speeds with top down. Stock radio, dash, door and rear speakers. No problems so far.
2006 V6 Mustang
2008 ML 350
Old 08-26-2015, 09:50 AM   #18
Hmm, those Infinity speakers are 2ohm...which means they should likely work with the OEM Bose system too...
'02 Boxster S
'16 GTI PP
'17 Bolt (with a B)
Nmbrsix is offline   Reply With Quote
Old 08-26-2015, 11:50 AM   #19
Porsche9's Avatar
Nice work.
I know this is a common issue, poor sound quality, but that's never been an issue in my Boxster. It not great but not bad enough that I ever cared. Works just fine up to about 80 mpg with the top down. I do have the door speakers so that helps. Maybe the PO upgraded the speaker. Glad to see upgrading is easy enough as Im sure at some point my speakers will crap out.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 08-26-2015, 03:00 PM   #20
lkchris's Avatar
Or, it could be an age thing ... my age.
We'll see ... but other mods are more fun in the meantime so will just let them get more worn before replacing them.
Kent Christensen
Albuquerque
2001 Boxster
2 BMW motorcycles
