Old 08-25-2015, 06:25 PM   #14
lkchris
lkchris's Avatar
Add rear speakers, they make the most difference.
They are good for sure.
Interesting thing when you have M490 (door subwoofers and amp) is that the amp has inputs for rear speakers but no output connection. For this, just find a 6x40 amp from a 996 to replace your 4x40 and insert the pins of the rear speaker harness in the empty spots in the output connector and you're good to go. 996 amp is same physical size, fits existing bracket, and existing harnesses connect right up. A little modding of output connector is required but pins stay the same.
996 amps come in coupe and cabrio versions. First one I tried was coupe and I was underwhelmed. A cabrio version made a significant difference, so much so that it's as if it's the first time I've actually heard my door speakers sounding like subwoofers.
This is as far as I'm going for now, as the radio is inaudible at highway speeds and will see if next tire set improves that enough to consider more stereo power. Maybe some dynamat in doors.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
