Old 06-11-2016, 07:07 AM   #101
oldskool73's Avatar
Hey guys, I need some help with this, I've built this twice now and I just can't get it to work. The code and electronics in theory are working fine, I've breadboarded it all up with a couple of led's to simulate the top motor and can turn them on and off with the buttons, but when I get it in the car... nothing.
If I put a multimeter between the regular harness and switch, when I press the button I see 12v @ ~70ma when the top's moving, which drops to ~10ma when the top stops. But when I do it between the arduino and the harness I see 12v @ ~30ma. I'm guessing this is the reason it doesn't work, not pushing enough power through to activate the motor, but I don't know why?
I've built it twice now, thinking I must have screwed up the first one, but the second has exactly the same result :/
The only difference I can see in my build is I'm using a nano, which has no +/- and only 2 GND. So the VR goes to the VIN and one GND, leaving one free GND which I connect to from the harness, and which both switches (via the 10k resistors) and both transistors (via the collector pins) are wired to. Is this wrong?
I'm just a simple software guy, so all these wires and pins confuse me. Any help appreciated!
Thanks!
oldskool73 is offline   Reply With Quote
Old 06-28-2016, 09:21 AM   #102
jpc763's Avatar
Originally Posted by Polaris View Post
Parts List:
-5 male automotive crimp-on connectors
-5 female automotive crimp-on connectors
-1 splice connector
I ordered the Arduino Nano board for $5.88 shipped. ATMEGA328 Compatible Nano V3 Improved Version Board with USB Cable for Arduino | eBay
I have put all of the components in a cart on Mouser and am now trying to get the connectors.
Does anyone know the specifics of these automotive crimp-on connectors so that they fit between the harness and the switch?
Thanks, John
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 06-28-2016, 10:43 AM   #103
On the slippery slope
JayG's Avatar
Thanks, John
they are just regular 1/4" push on terminals
Gardner Bender 16-14 AWG 0.250 in. Disconnect F TAB (75-Pack)-75-143F - The Home Depot
I used an insulated version
http://www.homedepot.com/p/Gardner-Bender-1-4-in-Blue-Fully-Insulated-Wire-Disconnects-15-Pack-15-153F/202521914
2004 996 Targa Tip
Instructor - San Diego region
Old 06-28-2016, 11:57 AM   #104
jpc763's Avatar
Thanks! I ordered the components and will go to HD to get the connectors! Can't wait to get this project rolling!
John
Old 06-28-2016, 01:25 PM   #105
JayG's Avatar
John
Make sure you get the correct ones for the wire gauge you are using.
IIRC, I used red ones. The package tells you what gauge wire will fit
2004 996 Targa Tip
Old 06-28-2016, 02:00 PM   #106
jpc763's Avatar
What gauge wire should I be using?
John
Old 06-28-2016, 02:27 PM   #107
JayG's Avatar
John
I used 16 gauge, so I guess I used blue terminals
2004 996 Targa Tip
Old 07-01-2016, 01:45 AM   #108
geraintthomas's Avatar
Thanks!
Personally I'd buy a One just to be absolutely sure that everything is the same as the build. I did and it works as I didn't want to get anything wrong. Originally I bought a cheap ebay rip-off and it didn't work, then I bit the bullet and bought a proper Arduino One for Ł20 and it worked first time
Porsche Boxster S Type 986
Bi-xenon Headlight Upgrade | 987 S 18" Anthracite Alloys | Android Head Unit | 5000k 55w HID's | 5000k Cree DRL's | 5000k Cree number plate lights | Cree LED Indicators | One-touch roof operation | Bypass exhaust pipes | Parking sensors | Ambient footwell lighting
geraintthomas is offline   Reply With Quote
Old 07-07-2016, 10:52 PM   #109
oldskool73's Avatar
Thanks @geraintthomas, gonna hang on and see if @jpc763 has any luck with his nano first, hopefully he reports back...
Old 07-08-2016, 08:57 AM   #110
jpc763's Avatar
I will post when I complete the project.
Old 07-16-2016, 07:13 PM   #111
jpc763's Avatar
Schematic:
OK, finally got a chance to take a few pics
OK. I am starting the project and have a few questions. I was a code guy back in the day but have done some electronics. I am using a breadboard to wire it up before I solder everything together.
Here is a picture of my nano. I am trying to figure out how to match the pinouts from Polaris's Arduino. Mine is more like JayG.
I assume that the "-" on the end is simply ground and will solder to the other ground wires. The "+" is a question as I have both 5v, 3.3v and pow pins. So, which do I connect the power regulator to?
Old 07-16-2016, 09:19 PM   #112
JayG's Avatar
The regulator connects to +5v
2004 996 Targa Tip
Old 09-14-2016, 08:14 AM   #113
Beriaan's Avatar
Does anyone have the shcematic for the arduino nano? It is hard to find out wich is the pin out number on the arduino nano it is very different then the schematic that polaris did.
Thanks guys!
André :
Beriaan is offline   Reply With Quote
Old 09-16-2016, 08:53 AM   #114
Everything is on the digital pins, and it should correspond to the same pin-out numbers even if they are in a different order.
Alternatively, all the pinouts are set up through constants, so you can change the pinouts the code uses by changing the constants at the top of the code before compiling and uploading to your arduino.
I have made this successfully with both the arduino one (my original version) and eBay Chinese nanos without issue, so it should be possible.
Polaris is offline   Reply With Quote
Old 03-02-2017, 12:38 PM   #115
Hello Polaris,
Coming late to the AutoTop party.
The link to the arduino code is broken in your original post.
Where can I find the code?
Thank you in advance.
mikehkang is offline   Reply With Quote
Old 03-02-2017, 03:36 PM   #116
oldskool73's Avatar
@mikehkang - you can grab it from my github if you need, this first commit is just an import of @Polaris's original code .... https://raw.githubusercontent.com/oldskool73/autotop986/4080d0e94c0b5fdb2546379d614b5992477a9e4d/autotop986.ino
Old 03-03-2017, 06:07 PM   #117
Thank you oldskool73!!
P. S. Do you also know where I can get the circuit diagram? Thank you in advance.
Old 03-13-2017, 07:48 AM   #118
Auto Locksmith
Hi Guys.
If anyone has the schematic I would be most grateful.
VIW9419 is offline   Reply With Quote
Old 03-13-2017, 04:20 PM   #119
JayG's Avatar
Here is the Schematic
2004 996 Targa Tip
Old 03-13-2017, 04:22 PM   #120
Auto Locksmith
Thanks, I will build it tomorrow.
