Old 06-18-2015, 05:06 PM   #121
2002 Boxster S
Does anyone know how loud these are in Db? I ask because I DE my car and both tracks near me have sound check restrictions.
2002 Boxster S
Ottacat is offline   Reply With Quote
Old 06-18-2015, 05:46 PM   #122
happygilmour's Avatar
Read my post. The question is do I need 2 or 4? Both ends of the U pipe or just the muffler end. And no word on the Hanger mounting bolts? Don't be such a turd Slate. Ok, I'm calm again too.
_________________
1999 BOXSTER
happygilmour is offline   Reply With Quote
Old 06-18-2015, 06:04 PM   #123
Fintro11's Avatar
Omg, man that sounds far better than mine :/ This mod has to be day-and-night for you. Nice vid comp
lol the one U pipe came off the clamp and was sitting a inch from the muffler :P haha
do you have the secondary cat delete ?
Old 06-21-2015, 06:33 PM   #124
Ok...now I'm stumped. I installed the 2" Easy clamp from NAPA...now called 2" SafetyClamp. I can't get them tight! I've tightened them down all the way and they still float on the pipe. My pipes seem to be 1 7/8" not 2". Anyone else found this? This is the connection from the muffler to the U pipe.
_________________
1999 BOXSTER
Old 06-21-2015, 06:54 PM   #125
ASE Certified Idiot
gtoger's Avatar
Unfortunately I do not have any wisdom for you on this one, as I had mine welded. I really don't like exhaust leaks...
2003 Porsche 986 Boxster S, Black / Tan
RIP: 1998 Porsche 986, Arena Red / Savanna Beige (wrecked)
1990 Pontiac Trans Am GTA .:. 1990 Corvette ZR-1 (#1930) .:. 1992 Pontiac Firehawk (#010)
1931 Ford Model A Tudor .:. 1967 Pontiac GTO .:. 1986 Pontiac Trans Am basket-case
gtoger is offline   Reply With Quote
Old 06-21-2015, 06:59 PM   #126
ASE Certified Idiot
gtoger's Avatar
That's a tricky one to answer. How loud at what distance? Under what conditions? Anyone with a smartphone can get a db reading that won't be dead on, but will put you in the ballpark. But obviously the loudness at idle from 15 feet (5 meters for you Metric types) will be a lot different than 6000 rpm at the the same distance.
As a strictly non-scientific answer, they're not so loud as to generate complaints from my neighbors or my wife. I'd say generally no louder than my GMC pickup with the Duramax diesel.
Old 06-21-2015, 07:45 PM   #127
BruceH's Avatar
From the muffler to the U pipe, I used the OEM clamps, the easy clamp was only used for the cat bypass pipe connections in my installation. I looked at my connections and the muffler to the U pipe is definitely a smaller diameter, so yes, you would need a smaller easy clamp for that connection.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 06-22-2015, 08:29 AM   #128
Thanks Bruce. That's what I thought. So the info in earlier posts saying you can use the 2" easy clamps on the U pipe to muffler connect is wrong. And from what I can see the smallest Easy Clamp is 2".
_________________
1999 BOXSTER
Old 06-22-2015, 08:35 AM   #129
Fintro11's Avatar
I think you have to hammer the U pipe into the muffler a bit then clamp, I butted the U and the muffler and it keeps sliding out
Old 06-22-2015, 09:11 AM   #130
BruceH's Avatar
I must have missed that post or just didn't pay attention. It takes some fiddling to get the U pipe connected to the muffler, but once you do, the OEM clamps work well for that connection.
DEPO Tail Lights
Old 06-22-2015, 09:39 AM   #131
Fintro11's Avatar
The U part has to be pushed into the muffler pipe correct? The cat delete / u pipe is butted though?
Old 06-22-2015, 10:22 AM   #132
BruceH's Avatar
That sounds correct, but it has been a while since I did mine. You are using the step down pipe from the Cat delete pipes, right?
DEPO Tail Lights
Old 06-22-2015, 10:45 AM   #133
Fintro11's Avatar
Yep that's not the trouble spot though it's where it hits the muffler
Old 06-25-2015, 01:40 PM   #134
Fintro11's Avatar
Fixed, cut a bit off the U pipe shoved it in the muffler and clamped tight.
Old 06-25-2015, 09:32 PM   #135
BruceH's Avatar
Glad to hear, how does it sound now?
DEPO Tail Lights
Old 06-26-2015, 05:17 AM   #136
You know it sounds Kickarse now
Old 06-26-2015, 03:41 PM   #137
Fintro11's Avatar
way more quiet, nice growl in the higher rpm. I think I am going to do the headers next
Old 06-27-2015, 09:11 AM   #138
hey Martin, can you redo your before/after video now that its fixed?
Old 06-28-2015, 10:02 AM   #139
Fintro11's Avatar
Try this,
https://www.facebook.com/Martin.944/videos/1006029796088361/
Old 06-28-2015, 07:02 PM   #140
Has anyone tried something like this for the drone. Early models don't have the double cats, so we can't do the cat delete or Easy Clamp.
Exhaust drone - solved
_________________
1999 BOXSTER
