Old 06-21-2015, 08:45 PM   #127
BruceH
BruceH's Avatar
Originally Posted by happygilmour View Post
Ok...now I'm stumped. I installed the 2" Easy clamp from NAPA...now called 2" SafetyClamp. I can't get them tight! I've tightened them down all the way and they still float on the pipe. My pipes seem to be 1 7/8" not 2". Anyone else found this? This is the connection from the muffler to the U pipe.
From the muffler to the U pipe, I used the OEM clamps, the easy clamp was only used for the cat bypass pipe connections in my installation. I looked at my connections and the muffler to the U pipe is definitely a smaller diameter, so yes, you would need a smaller easy clamp for that connection.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
