06-18-2015, 06:06 PM
#121
2002 Boxster S
Does anyone know how loud these are in Db? I ask because I DE my car and both tracks near me have sound check restrictions.
2002 Boxster S
06-18-2015, 06:46 PM
#122
Read my post. The question is do I need 2 or 4? Both ends of the U pipe or just the muffler end. And no word on the Hanger mounting bolts? Don't be such a turd Slate. Ok, I'm calm again too.
_________________
1999 BOXSTER
06-18-2015, 07:04 PM
#123
Originally Posted by Nine8Six
Omg, man that sounds far better than mine :/ This mod has to be day-and-night for you. Nice vid comp
lol the one U pipe came off the clamp and was sitting a inch from the muffler :P haha
do you have the secondary cat delete ?
06-21-2015, 07:33 PM
#124
Ok...now I'm stumped. I installed the 2" Easy clamp from NAPA...now called 2" SafetyClamp. I can't get them tight! I've tightened them down all the way and they still float on the pipe. My pipes seem to be 1 7/8" not 2". Anyone else found this? This is the connection from the muffler to the U pipe.
_________________
1999 BOXSTER
06-21-2015, 07:54 PM
#125
ASE Certified Idiot
Unfortunately I do not have any wisdom for you on this one, as I had mine welded. I really don't like exhaust leaks...
2003 Porsche 986 Boxster S, Black / Tan
RIP: 1998 Porsche 986, Arena Red / Savanna Beige (wrecked)
1990 Pontiac Trans Am GTA .:. 1990 Corvette ZR-1 (#1930) .:. 1992 Pontiac Firehawk (#010)
1931 Ford Model A Tudor .:. 1967 Pontiac GTO .:. 1986 Pontiac Trans Am basket-case
06-21-2015, 07:59 PM
#126
ASE Certified Idiot
That's a tricky one to answer. How loud at what distance? Under what conditions? Anyone with a smartphone can get a db reading that won't be dead on, but will put you in the ballpark. But obviously the loudness at idle from 15 feet (5 meters for you Metric types) will be a lot different than 6000 rpm at the the same distance.
As a strictly non-scientific answer, they're not so loud as to generate complaints from my neighbors or my wife. I'd say generally no louder than my GMC pickup with the Duramax diesel.
06-21-2015, 08:45 PM
#127
From the muffler to the U pipe, I used the OEM clamps, the easy clamp was only used for the cat bypass pipe connections in my installation. I looked at my connections and the muffler to the U pipe is definitely a smaller diameter, so yes, you would need a smaller easy clamp for that connection.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
06-22-2015, 09:29 AM
#128
Thanks Bruce. That's what I thought. So the info in earlier posts saying you can use the 2" easy clamps on the U pipe to muffler connect is wrong. And from what I can see the smallest Easy Clamp is 2".
_________________
1999 BOXSTER
06-22-2015, 09:35 AM
#129
I think you have to hammer the U pipe into the muffler a bit then clamp, I butted the U and the muffler and it keeps sliding out
06-22-2015, 10:11 AM
#130
I must have missed that post or just didn't pay attention. It takes some fiddling to get the U pipe connected to the muffler, but once you do, the OEM clamps work well for that connection.
DEPO Tail Lights
06-22-2015, 10:39 AM
#131
The U part has to be pushed into the muffler pipe correct? The cat delete / u pipe is butted though?
06-22-2015, 11:22 AM
#132
That sounds correct, but it has been a while since I did mine. You are using the step down pipe from the Cat delete pipes, right?
DEPO Tail Lights
06-22-2015, 11:45 AM
#133
Yep that's not the trouble spot though it's where it hits the muffler
06-25-2015, 02:40 PM
#134
Fixed, cut a bit off the U pipe shoved it in the muffler and clamped tight.
06-25-2015, 10:32 PM
#135
Glad to hear, how does it sound now?
DEPO Tail Lights
06-26-2015, 06:17 AM
#136
You know it sounds Kickarse now
06-26-2015, 04:41 PM
#137
way more quiet, nice growl in the higher rpm. I think I am going to do the headers next
06-27-2015, 10:11 AM
#138
hey Martin, can you redo your before/after video now that its fixed?
06-28-2015, 11:02 AM
#139
06-28-2015, 08:02 PM
#140
Has anyone tried something like this for the drone. Early models don't have the double cats, so we can't do the cat delete or Easy Clamp.
Exhaust drone - solved
_________________
1999 BOXSTER
