Old 02-24-2015, 12:55 PM   #181
98 Arctic silver 986
tommy583's Avatar
They look cheap, halogen bulbs, plastic projector (fire is hot), LEDs are low quality (burn out), they look cheap and I wouldn't put them on my Dodge Neon, they don't actually fit in/on the car, the alignment pegs break off due to low quality brittle plastic, they look cheap and very "Walmart", foam rubber surround gasket holds water and rots sealant between outer lens and headlight body allowing water and dirt infiltration, "chrome" flakes off, paint flakes off, full of "cooling holes" which also let dust, dirt and water in.
I'm sure that I'm missing something. Did I mention that they look cheap?
I'm shocked and amazed that anyone would ever even consider putting this junk on their car.
At least they don't look cheap .
Old 02-24-2015, 02:05 PM   #182
I guess I came across a little strong, there
Old 02-24-2015, 02:50 PM   #183
tommy583's Avatar
No I don't think so. They look like something from walmart for sure. It's hard to believe they charge that much for them. I guy around me bought a pair. He loves them, but I don't. I may be a little biased
Old 02-24-2015, 03:04 PM   #184
steved0x's Avatar
There was a guy at RRR with a yellow boxster that had them, they actually looked pretty good on his and matched his theme, which had a lot of mods, badges, spoilers, etc. It looked good on his.
Old 02-24-2015, 03:35 PM   #185
BruceH's Avatar
Not really. They ARE expensive for what they are. Fred's kit with your install makes a much nicer product for less
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 01-19-2016, 12:33 PM   #186
mikesz's Avatar
I am trying to de-amber with a belt sander. I tried Particlewave's technique with a dremel but didn't work for me.
99 Porsche Boxster
Old 04-10-2016, 10:21 AM   #187
Krazy_Kameleon's Avatar
deamber
I have just done the same thing. started out with a 'MOUSE' sander and resorted to a belt sander with 80grit. what a job! that amber stuff has to be the toughest plastic I have ever had the misfortune of dealing with.
I then gradually worked up with finer and finer grit until 600. I used this all over the light as there was a lot of yellowing and some scratches that I wanted to remove.
The trouble is that the standard indicator it not 'smoked' so it doesn't match the cleared/ smoked headlight corners.
I am going to have to split the lens from the housing now and then spraypaint he insides black/ gun metal.
I have taken pics of this process and will post them when I have completed the job.
This is not a job for the fainthearted
Rich
Krazy_Kameleon is offline   Reply With Quote
Old 09-07-2016, 11:08 PM   #188
Rich
How did you manage? Pictures?
When you sanded the amber off did you get to a clear lens under it?
jbryshun is offline   Reply With Quote
Old 09-07-2016, 11:46 PM   #189
Yes, he did. They are all clear underneath the amber.
See here - http://986forum.com/forums/general-discussions/51810-our-amber-headlights-can-de-ambered.html
Old 09-08-2016, 01:14 AM   #190
It's surprising how thick the plastic is - just keep sanding.
I have since sold the first pair I did and bought a 2nd pair of amber lights to de-amber.
Things I learned from the first time around:
1. Mask off the rest of the headlight before sanding the amber section - this makes it a whole lot less work when you need to polish up the headlight at the end
2. Sand off the amber slowly allowing time to cool - I used a lot of water. If you apply too much pressure the plastic melts and liquifies. this heat can cause distortion that blemishes the entire lens right through the clear underneath.
3. make sure you use the 'sealer' in your lens restoration kit afterward. I didn't do this and lenses yellowed again very quickly
hope that helps
Old 12-27-2016, 08:36 PM   #191
hi ... is it possible for you to send me these pics or repost them?
Originally Posted by geetee View Post
Edinh81 is offline   Reply With Quote
