Old 09-07-2016, 11:08 PM   #188
jbryshun
Originally Posted by Krazy_Kameleon View Post
I have just done the same thing. started out with a 'MOUSE' sander and resorted to a belt sander with 80grit. what a job! that amber stuff has to be the toughest plastic I have ever had the misfortune of dealing with.
I then gradually worked up with finer and finer grit until 600. I used this all over the light as there was a lot of yellowing and some scratches that I wanted to remove.
The trouble is that the standard indicator it not 'smoked' so it doesn't match the cleared/ smoked headlight corners.
I am going to have to split the lens from the housing now and then spraypaint he insides black/ gun metal.
I have taken pics of this process and will post them when I have completed the job.
This is not a job for the fainthearted
Rich
How did you manage? Pictures?
When you sanded the amber off did you get to a clear lens under it?
jbryshun is offline   Reply With Quote
