Old 10-22-2011, 11:49 AM   #1
will this bi-xenon projector fit?
This will not be an easy plug-n-play (pnp). I will have to cut/modify the reflector to fit this larger projector, then hide it with a shroud.
I'm going this route instead of a smaller pnp projector because I want the most controlled illumination possible.
I'll probably buy the kit from TRS Bi-xenon FX-R Stage III Kit - Complete Retrofit Kits from The Retrofit Source Inc unless someone knows a better vendor.
About 2 months ago, madmods posted a bi-xenon retrofit seen below. He didn't specify what kind of projector he used, but I'm assuming it was a smaller pnp. It looks nice and similar to the Mini H1 kit that TRS sells.
Any opinions would help before I pull the trigger and get out the hacksaw.
baxster is offline   Reply With Quote
Old 10-22-2011, 11:58 AM   #2
I should add that the reflector in my 04 is about 5.5" tall. The projector that I'll looking at is 100mm (~4") tall. Sounds doable unless I'm missing something.
Old 10-23-2011, 12:44 PM   #3
What was your experience if you've tried to modify your headlights?
Old 11-01-2011, 06:38 PM   #4
Registered Boxster abuser
healthservices's Avatar
I think you just use the reflector off the old headlight right?
My question is how do you do your adjustments to the xenon?
Old 11-02-2011, 10:26 PM   #5
For the projector shown, the reflector would have to be cut, and the projector bolted or JB welded or both to the reflector.
By "adjustments" I assume you mean aiming the light. The adjustment moves the reflector, so as long as you don't affect that system it shouldn't be a problem.
This should be a better system (for light performance) than litronics because a bi-zenon projector uses the entire light potential on high beam vs just half the projector with litronics.
Old 11-21-2011, 11:26 AM   #6
any updates?
