Old 10-22-2011, 10:49 AM   #1
baxster
will this bi-xenon projector fit?
This will not be an easy plug-n-play (pnp). I will have to cut/modify the reflector to fit this larger projector, then hide it with a shroud.
I'm going this route instead of a smaller pnp projector because I want the most controlled illumination possible.
I'll probably buy the kit from TRS Bi-xenon FX-R Stage III Kit - Complete Retrofit Kits from The Retrofit Source Inc unless someone knows a better vendor.
About 2 months ago, madmods posted a bi-xenon retrofit seen below. He didn't specify what kind of projector he used, but I'm assuming it was a smaller pnp. It looks nice and similar to the Mini H1 kit that TRS sells.
Any opinions would help before I pull the trigger and get out the hacksaw.
baxster is offline   Reply With Quote
