For the projector shown, the reflector would have to be cut, and the projector bolted or JB welded or both to the reflector.
By "adjustments" I assume you mean aiming the light. The adjustment moves the reflector, so as long as you don't affect that system it shouldn't be a problem.
This should be a better system (for light performance) than litronics because a bi-zenon projector uses the entire light potential on high beam vs just half the projector with litronics.
