Old 03-11-2009, 06:47 PM   #1
Unhappy refurbishing wheel caps
folks,
i'm sure somebody already had tackle this project before? my wheel caps are faded and not sure to go about it safely.. much appreciated..
thank you
t2-bxtrs is offline   Reply With Quote
Old 03-11-2009, 06:54 PM   #2
bmussatti
Guest
Posts: n/a
Heck, buy one of these options, and be done with it in a matter of minutes:
http://e-partssales.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=P&Category_Code=986CenterCaps
Old 03-11-2009, 06:59 PM   #3
Smile caps
there we go.. easy replacement.
thank u
Old 03-11-2009, 07:04 PM   #4
bmussatti
Guest
Posts: n/a
I say buy the "turbo" caps!
I guy can dream......can't he?
Old 03-13-2009, 07:23 PM   #5
My emblems started to look dingy with a milky White layer of film. I rubbed them out with some wet/dry 2000 grit sandpaper, followed by an application of 3M polishing compound by hand. They look good as new.
Rareair is offline   Reply With Quote
Old 04-05-2009, 06:35 AM   #6
Sanding Works
I did the same thing as Rareair and it works. Started with 1500 grit wet dry sandpaper and then finished with 2000 grit. For good measure I shot them with 3 light coats of wheel clearcoar (duplicolor in the spray can form Autozone). They look good as new and I saved some $.
MidMotor2TrunkToter is offline   Reply With Quote
Old 04-05-2009, 08:42 AM   #7
I took the easy route and just cleaned mine off real good and applied clear nail polish to the colored portion. It brought them back to life real good.
Once they dried I figured what the heck, I taped over the crest portion and then repainted the silver portion using the Wurth Silver spray paint.
Real easy, took 10 minutes tops and they look almost as good as new.
:dance:
http://i240.photobucket.com/albums/f...r/carlit-1.jpg 2003 Boxster S
spyder803 is offline   Reply With Quote
Old 04-05-2009, 07:18 PM   #8
Porsche "Purist"
Paul's Avatar
Figures the GT3 caps are way cheaper at $18 each. Wonder if they fit our wheels?
1987 924S. 2002 996TT. PST-2
