12-16-2018, 12:58 PM
The old Adjustable LCA-question..
To adjust or not to adjust...
Well anyway, we know that adjustable LCA:s are costly, eg OEM GT3-arms.
The Eibach seems pretty reasonable priced. https://www.design911.co.uk/fu/prod136142/Adjustable-Lower-Control-Arm-Kit-for-Porsche---EIBACH/
Those are supposed to be rebranded SPC-units. However I read that some eg. Steved0x had some issues with something coming loose (Did not really understand what part.) Also if I understood it correctly there are some revised versions where this should have been adressed. Does anyone have the latest news on this? Can I see on the pictures if the part is revised or not?
We should really have some consensus on the adjustable LCA-thing.. We all want them..
12-16-2018, 01:20 PM
Stock arms have shims to install and are bolted end to end. Little to no chance that it will slip or adjust on it's own. These have slotted holes, and I would not trust that under track loading. If they would slip under load you could have a serious handling issue.
12-16-2018, 01:51 PM
This threaded cap is what comes loose on the old design, this is a photo is of the revised part, the threaded boss and bolt retains the cap.
I would have no hesitation to run this new design.
12-16-2018, 02:23 PM
I'll have to check my sheets, i think i ran those arms on maybe 15-20 track days and while i had trouble with the cap unthreading, i never had any trouble with the adjustment part (the big bolt that you turn to extend/retract the inner end and the 4 bolts that lock down the big bolt).
12-27-2018, 06:09 AM
Thanks for reply, sorry for slow response.. Got stuck in the whole x-mas thing ;-)
I ended up ordering the GT3-arms from FVD, looks like IŽll get them tomorrow so then I know if they really are OEM brand or not.
Next stops on the slippery slope:
1) Since the main cornering force would be transferred to the frame via the inner part/bushing I would like to swap this to solid, (spherical bearing), to keep camber intact at heavy cornering. What options do we have? (IŽll report back when I have found something)
2) I see advices regarding swapping the thrust arm bushing to solid, I cannot really understand why that would be super important, but hey.. What parts can we find?
3) My car is a daily driver but I want to keep it very track focused anyway, what camber do I dare aim for. Now I have approx -0.9 and that is obviously far too little, so IŽm thinking 2-2.5 might be reasonable to try. Any thoughts?
4) Given the camber setting according to bullet 3 above, what camber might be reasonable on the rear? Would I reach it with oem specs or do I need adjustable LCA:s in the rear too?
Tires are Cup-2 but next summer the plan is Trofeo R.
IŽm having fantasies about Öhlins R&T but, weŽll get there later...
12-27-2018, 06:39 AM
There are several retrofit options, but a catch is that the inner diameter of where the rubber bushing goes must be the same as OEM Porsche. For example, the Meyle LCA has an inner diameter that is around 1mm or so bigger, and so the monoball cartridge retrofits don't work. If you have OEM GT3 LCA, it should be fine but I would check with the sellers of the cartridges to be sure (although for the price you could get a new inner end that may be rebuildable)
Cartridge:
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-monballs~bushings-/lower-control-arm-monoball-bushing-996-001-detail.htm
Sealed Monoball Set-Rennline, Inc.
Eccentric monoball (not really needed since you have adjustable LCA)
https://www.elephantracing.com/porsche/boxster-cayman/monoball-suspension-bearings-for-986-987/#front-lower-wishbone-control-arm-eccentric-monoballs
If you are getting GT3 style LCA then instead of retrofitting a cartridge, you can just gt a whole new end.
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-monballs~bushings-/lower-control-arm-monoball-996-997-boxster-cayman-lcamb996-detail.htm
3-307 XL Inner Spherical Bearing (Mono-ball) End Kit: Set of 2 - RSS / Road Sport Supply
3-256 Inner Spherical Bearing (Mono-ball) End Kit: Set of 2 - RSS / Road Sport Supply
12-28-2018, 06:50 AM
Because Pelican owns this forum and when they bought it, they started censoring competitors websites. Just spell out the site with some spaces between some letters and it should be OK
12-28-2018, 07:41 AM
I see.. ok hope I donŽt break any forum rule if I spell it out.. ItŽs C A R I D .com They also have the Torque Solution Thrust Arm Bushing kit for 215USD, I might look into that.
12-29-2018, 09:06 PM
Who's askin'?
So.... ? How 'bout it? Do we have a consensus yet, on which LCA's make the most sense, and offer the best value?
12-30-2018, 02:19 AM
We might be getting there.. Here is my candidate: https://www.fvd.net/de-en/99634105391/front-control-arm-left-adjustable-motorsport.html
Those are the ones I ordered and they are actually complete with shims AND the inner part! OEM-part that looks great! I donŽt see how you can beat that price.
12-30-2018, 02:25 AM
Have searched but not really found.. I plan to still DD my car but want it as trackable as possible, comfort is not my thing. Does it make sense with 2,5-ish Neg camber in the front then? And the big question: What about the rear, would it then make sense with approx -2degrees in the rear, and can that be dialed in without adjustable LCA:s? Need to know if I should order adjustable or regular in the rear..
12-30-2018, 07:39 AM
With Tarret camber plates in the front, factory LCAs and M030 ROW springs/struts, I get-2.2 on the front and -2.5 in the rear. That is maxed out on the camber. I suppose I could get more if I wanted to slot the shock towers, but I don't like that idea
It works great on the track and I don't get excessive tire wear on the street
12-30-2018, 08:00 AM
Who's askin'?
By "factory" you mean OEM 986 LCA's?
12-30-2018, 08:08 AM
Wow, I hadn't looked at those FVD adjustable LCAs. How much was tax and shipping on those? How many shims and what thickness?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
12-30-2018, 08:53 AM
Yes, plane jane standard LCAs
12-30-2018, 03:43 PM
256EUR is including tax it was approx 30EUR in shipping to me in Sweden.
Shims:
1x10mm
5Ś1mm
12-30-2018, 05:44 PM
Does FVD ship to the USA?
They don't have USA listed for shipping
12-30-2018, 06:04 PM
Who's askin'?
Google fvd, instead of following the link. You'll find the us site.
12-31-2018, 02:29 PM
OK they are in Pompano Beach, FL.
These controls arms are $316 each, shipped out of Germany.
I'm debating: Elephant Quick Change camber plates or these... What is the benefit of these LCAs over the elephant camber plates that provide 2 deg extra camber?
