Old 12-27-2018, 06:39 AM   #6
steved0x
steved0x's Avatar
Originally Posted by Robert986 View Post
1) Since the main cornering force would be transferred to the frame via the inner part/bushing I would like to swap this to solid, (spherical bearing), to keep camber intact at heavy cornering. What options do we have? (IŽll report back when I have found something)
There are several retrofit options, but a catch is that the inner diameter of where the rubber bushing goes must be the same as OEM Porsche. For example, the Meyle LCA has an inner diameter that is around 1mm or so bigger, and so the monoball cartridge retrofits don't work. If you have OEM GT3 LCA, it should be fine but I would check with the sellers of the cartridges to be sure (although for the price you could get a new inner end that may be rebuildable)
Cartridge:
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-monballs~bushings-/lower-control-arm-monoball-bushing-996-001-detail.htm
Sealed Monoball Set-Rennline, Inc.
Eccentric monoball (not really needed since you have adjustable LCA)
https://www.elephantracing.com/porsche/boxster-cayman/monoball-suspension-bearings-for-986-987/#front-lower-wishbone-control-arm-eccentric-monoballs
If you are getting GT3 style LCA then instead of retrofitting a cartridge, you can just gt a whole new end.
https://www.tarett.com/items/986-987-981-718-products/986-987-981-718-suspension/986-987-981-718-monballs~bushings-/lower-control-arm-monoball-996-997-boxster-cayman-lcamb996-detail.htm
3-307 XL Inner Spherical Bearing (Mono-ball) End Kit: Set of 2 - RSS / Road Sport Supply
3-256 Inner Spherical Bearing (Mono-ball) End Kit: Set of 2 - RSS / Road Sport Supply
