Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 05-18-2017, 02:45 PM   #41
Lemming's Avatar
Picked the car up from the cage builder today. Took a few quick pics, failed to get on showing bars going to the front strut mounts.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
Lemming is offline   Reply With Quote
Old 05-18-2017, 04:14 PM   #42
Nice! Looks great!
Old 05-18-2017, 05:30 PM   #43
Lemming's Avatar
I'm pleased with it. There are one or two things I would like to be different. The rear harness bar is straight and nearly against my seat. This setup will not work for a longer-legged person, but the bar can easily be replaced. We did look into an FIA bar, but I did not think there would be enough room for rapid egress (I've been in a car that was on fire, so I want to be able to get out quickly). Now that it is completed, the builder did a great job moving the doors outward and keeping them fairly low, yet safe. I'll run this way for the first few tests and then decide if I need another bar. The car has much better ingress and egress than my 944LS. I am glad he was able to tie in the front strut towers.
Tim
1999 986 (SPB)
Old 05-23-2017, 07:06 AM   #44
Lemming's Avatar
Exhaust system is just about done, just need to decide if I'm using two or one tips, clean up some welds, and black out the entire exhaust with high-temp black paint. Using turbo perforated mufflers and 2" exhaust tubing from the headers.
Tim
1999 986 (SPB)
Old 05-31-2017, 07:35 AM   #45
Lemming's Avatar
Aligned the car on Monday and roll cage painting has begun. Made a plate to insert into the dash for switches and gauges. Photos to come. T-minus 10 days to first real testing.
Tim
1999 986 (SPB)
Old 05-31-2017, 09:23 AM   #46
PGas32's Avatar
What are you using to paint the cage? I was in a rush and didn't paint mine before reassembling the car...will probably make that a project for this winter
2002 Boxster S
2001 911 race car
Gone:
Spec Boxster #714, 2006 Cayman S, 2006 911 S, 2016 Cayenne GTS
PGas32 is offline   Reply With Quote
Old 06-01-2017, 05:31 AM   #47
Lemming's Avatar
Rustoleum. Cage will need one more coat, but you get the idea, going for a black/white livery. NOTE: I love the ease with which the doors can be removed, makes working on the interior so much easier.
Tim
1999 986 (SPB)
Old 06-01-2017, 07:03 AM   #48
rastta's Avatar
Looks great. Wish I had that style of cage with the lower bars - would make entering and exiting so much easier for this old guy :-)
rastta is offline   Reply With Quote
Old 06-01-2017, 07:32 AM   #49
Lemming's Avatar
And this old guy!
Tim
1999 986 (SPB)
Old 06-01-2017, 08:22 AM   #50
Tip: Apply clear racer's tape to some of the roll bar surfaces that have everyday contact with people and things. Especially the harness bar, cross bar, any unpadded door bars. It functions as a shiny paint protection that will keep the paint in much better shape for a longer time.
trygve is offline   Reply With Quote
Old 06-01-2017, 08:39 AM   #51
Lemming's Avatar
Not a bad idea.
Still trying to decide if I will paint the interior or not (white). On the plus side, it will keep the interior cooler and aid in finding items dropped on the floor. On the negative side, every time I've painted the interior of a car, it has looked like
Tim
1999 986 (SPB)
Old 06-02-2017, 07:30 AM   #52
Lemming's Avatar
Still need to add all the little bits and pieces to finalize the dash.
Tim
1999 986 (SPB)
Old 06-02-2017, 07:40 AM   #53
rastta's Avatar
What short shifter is that? Looks like the one I have and I don't know what came in my car.
Old 06-02-2017, 07:50 AM   #54
Lemming's Avatar
B&M knockoff
Tim
1999 986 (SPB)
Old 06-02-2017, 08:15 AM   #55
rastta's Avatar
Originally Posted by Lemming View Post
B&M knockoff
Thanks - I was thinking B&M based on photos but could be a knockoff as well. I'll be honest - I don't like it much. It could be just worn out - but it has no real spring "side" assist which makes it dicey going from 2-3. Have to make very deliberate shifts or I'll wind up in 5th.
Old 06-02-2017, 08:34 AM   #56
Lemming's Avatar
I like the feel, but have not driven on track with it yet. The throws are certainly short, but feel robust. A 2-5 shift won't kill you, but a 5-2 might hurt.
Tim
1999 986 (SPB)
Old 06-02-2017, 08:38 AM   #57
911monty's Avatar
Tried pulling the end bushings and re greasing yet? Could be dry and adjusted too tight since there is no spring assist built into the shifter. Most likely just dry. I pulled mine and also re greased the bearings in the lever assembly. Like new now.
Old 06-02-2017, 01:02 PM   #58
rastta's Avatar
I have not. Should have the car back by Monday - I'll take a look at it when I get the car back. Thanks for the tip.
Old 06-02-2017, 02:24 PM   #59
911monty's Avatar
You're very welcome! Be sure to pull that pivot bolt on the shaft, there is a roller bearing in there. Mine was so dry the rollers were frozen.
Old 06-05-2017, 08:48 AM   #60
Lemming's Avatar
Rear lexan window is in place (need to update the pic). I used well nuts (rubber) that are often used for motorcycle fairings. Easily removable to replace the window (or to remove to paint the top).
To secure the top, I've decided not to use Dzus fasteners as my experience is that they tend to pop open at the worst times. Instead, I'm going to use rivet nuts and large headed screws. This method will require a bit more time to attach/detach the roof, but at least I won't have to worry about the top coming off at speed.
Pic for attention.
Tim
1999 986 (SPB)
