Go Back   986 Forum - The Community for Porsche Boxster & Cayman Owners > Porsche Boxster & Cayman Forums > Boxster Racing Forum
Old 04-25-2018, 01:43 PM   #1041
House started the swap this morning at 9am. The old engine was out after lunch.
The pro's make it look easy (as compared to my hack DIY skills!).
Old 04-25-2018, 06:59 PM   #1042
So a 3.8L is going in Tom, I am sending the scrutineers
bkovac is offline   Reply With Quote
Old 04-25-2018, 08:29 PM   #1043
3.8's are soooo 2016. I assure you it'll be a 4.0 liter.
Old 04-25-2018, 10:09 PM   #1044
Tom... is it just the picture being somewhat distorted, or is that UDP all bent to hell?
Old 04-26-2018, 07:59 AM   #1045
I didn't take the photo so I don't know for sure but I'm going to guess that its a distorted photo. I plan to drop by the shop today and I'll confirm.
Old 04-27-2018, 10:22 AM   #1046
Everything has been swapped over and the replacement engine has been installed in the car! They should have it running by the end of the day.
They'll drive it on Monday to make sure that everything is ok and it should be ready for pickup on Tuesday.
The small pile of parts to the right of the top is the tip wiring harness, a/c compressor and lines, exhaust manifolds, and alternator (the bearing sounded rough so they swapped in the old one). The idler and tensioner pulley's were also replaced with new components since they were rough sounding.
Old 04-27-2018, 10:23 AM   #1047
Photo distortion. The UDP is fine.
Old 04-27-2018, 10:36 AM   #1048
Ok, check this out....
Here is the oil filter from the failed engine just as it came out of the engine. It looks like the oil pump was sucking so hard that it collapsed the filter. Is that possible? Weird.
There wasn't any metal in the oil or the oil filter but the shop said that they found coolant in the oil when they drained it. There is also a ton of oil in the intake runners. I plan to get the engine back to my workshop and will disassemble it to try to determine the exact failure.
And at the bottom is a pic of the failed engine looking pretty sad after being raided for parts to swap onto the replacement engine.
Old 04-27-2018, 11:57 AM   #1049
blown AOS resulting in a broken ring?
Old 04-27-2018, 03:52 PM   #1050
seningen's Avatar
I'm thinking that's the case -- was there any smoke out the back?
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 04-27-2018, 04:40 PM   #1051
911monty's Avatar
Let's try this one. Cracked cylinder/head #4/5 ? resulting in coolant in the oil. Oil filter is downstream of the oil pump so sees pressure not vacuum. Coolant saturated the paper filter media which swelled closed causing high DP across the media resulting in element collapse. Excessive vapor from coolant in the crankcase overwhelmed the AOS resulting in failure.
Old 04-27-2018, 05:23 PM   #1052
Mike
No smoke at all.
Old 05-01-2018, 09:53 AM   #1053
Replacement engine installed! Used engine runs great. I'll put some miles on it today and maybe run it on the dyno tomorrow...
Old 05-01-2018, 12:31 PM   #1054
AZ986S's Avatar
Failure mode #???
Yeah was going to say filter is post pump. I can’t think of another way that the oil filter collapsed other than it absorbed coolant/water. These are not designed for separating water. Maybe a synthetic media filter would have done better? I.E. spin on.
The other question is: did the coolant in oil make the AOS fail? Funny that there was no smoke but there was a ton of oil in the intake...
I’m thinking more and more that the AOS didn’t fail, that is was just oil starvation caused by the crushed filter, destroyed / spun bearing somewhere?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
Old 05-01-2018, 08:22 PM   #1055
Track rat
Topless's Avatar
I'm guessing failure of the engine oil cooler or an internal freeze plug causing intermix> collapsed filter> blown AOS> Oil in the intake. The motor is full of goo but if no metal debris it may be salvageable.
Old 05-01-2018, 09:37 PM   #1056
Originally Posted by AZ986S View Post
Failure mode #???
I'm having the old engine moved to my house and will do a tear down. Stay tuned...
Old 05-01-2018, 09:43 PM   #1057
I drove the car about 60 miles around LA's freeway's today (mid-day to avoid traffic!). Had the opportunity to do a few 0-80mph runs while shifting at redline on the 110 Frwy north of downtown LA where the freeway on-ramps are about one car length. Engine seemed to have good (normal) power and ran perfect.
The only thing that I noticed was that the water temp was a little higher than it used to be - and then I remembered that I forgot to have the shop swap over the low temp thermostat from the old engine to the replacement. Guess what I'm doing this weekend? (might even replace the water pump while I'm in there).
Off to the dyno tomorrow...
Old 05-06-2018, 09:05 AM   #1058
The dyno wasn't available last week so I decided to just go to Willow Springs on Friday to test. I did 4 x 30 mins sessions and the engine ran perfect. It was easy to do 1:35 lap times on a fairly warm day. I'll try to get onto the dyno this week just so I know where this engine stands in terms of power.
The most interesting thing about an open test day is some of the other cars that show up...
Like this LeMon's Flying Pig car...
Or this BMW spewing fuel from the right rear corner on every left hand turn...
Old 05-06-2018, 10:59 PM   #1059
Wow...
Old 05-14-2018, 10:10 PM   #1060
Some news what caused the engine failure? Oil filter looks pretty trashed. What brand was it?
