Old 05-01-2018, 12:31 PM   #1054
AZ986S
AZ986S's Avatar
Let's try this one. Cracked cylinder/head #4/5 ? resulting in coolant in the oil. Oil filter is downstream of the oil pump so sees pressure not vacuum. Coolant saturated the paper filter media which swelled closed causing high DP across the media resulting in element collapse. Excessive vapor from coolant in the crankcase overwhelmed the AOS resulting in failure.
Failure mode #???
Yeah was going to say filter is post pump. I can’t think of another way that the oil filter collapsed other than it absorbed coolant/water. These are not designed for separating water. Maybe a synthetic media filter would have done better? I.E. spin on.
The other question is: did the coolant in oil make the AOS fail? Funny that there was no smoke but there was a ton of oil in the intake...
I’m thinking more and more that the AOS didn’t fail, that is was just oil starvation caused by the crushed filter, destroyed / spun bearing somewhere?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
