Old 01-02-2007, 06:53 AM   #1
Roll bar trim removal question
I've searched the manuals for some clue as to how the trim is attached to the roll bar. I'm interested in removing it to paint them the body color but hessitate to just start prying or pulling them off but I see no other way that they might be fastened. Help would be appreciated. Also going to have rear bumperettes painted. 2000 non-S guards red. GS
rebeltown is offline   Reply With Quote
Old 01-02-2007, 07:13 AM   #2
bmussatti
Guest
Posts: n/a
There was a great post about this, with pictures, over on the www.renntech.org site several months ago. Maybe you can do a search, or post your question there.
Old 01-02-2007, 07:14 AM   #3
Send a message via MSN to CJ_Boxster
You basically wedge it off with a screw driver looking thing with a U-shaped tip... you always run a risk of breaking something there...even with the right tools from what i've read.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 01-02-2007, 09:22 AM   #4
I did check out the Renntech.org site and found a few helpful hints. I got them off alright but they are difficult even with a trim removal tool. I haven't decided yet whether I will paint the rollbar in place or remove it as removal requires cabrio top removal also...Thank you all for the help!
Old 01-02-2007, 05:18 PM   #5
You gotta use a trim tool and pull like you never pulled before..its a ******************** but they will come off...
docdyh is offline   Reply With Quote
Old 01-03-2007, 09:44 AM   #6
I used a large flathead screwdriver wrapped in a t-shirt. Pull the trim back and use a flaslight to see where it is attached, then pry at that spot. I was able to re-use all the plastic molly type pieces to put back into place. Even though almost everything is expensive with a Porsche, I would think replacing those plasic pieces as needed at the dealer would be pretty cheap. Pry away, it's not that hard and you don't need any special tools!
EB847 is offline   Reply With Quote
Old 01-04-2007, 01:29 PM   #7
After getting the trim off the rollbar with much effort while still in the car, I've decided to paint what I can with the "bar" still installed. Looks like a lot of work to get the bar disconnected from the cabrio in the first place. I'll mask off everything except what needs to be painted. I purchased the paint supplies from www.paintscratch.com and will paint my rollbar and rear bumperettes myself. I'll try to include some photos if it comes out good... Thanks to all.
Gary S.:dance:
2000 non-S Guards RED
Mostly stock-so far...
rear speakers
3 spoke
K+N
Red bumperettes
Speedster humps
Planning:
some stinkin' cup holders
