I used a large flathead screwdriver wrapped in a t-shirt. Pull the trim back and use a flaslight to see where it is attached, then pry at that spot. I was able to re-use all the plastic molly type pieces to put back into place. Even though almost everything is expensive with a Porsche, I would think replacing those plasic pieces as needed at the dealer would be pretty cheap. Pry away, it's not that hard and you don't need any special tools!
