08-02-2025, 04:07 AM
#661
Registered Member
Originally Posted by LoneWolfGal
I'm still alive, still getting things set up at my new place. In the meantime, since putting the car on jack stands will be my first order of business, I've been thinking about how to make the process less frustrating.
Consider the following:
With the floor jack under the rear crossmember, jack up the entire back of the car and place jackstands under the left and right side jacking points (just ahead of the wheel wells) and lower the car onto them.
At the front, jack from just behind the front wheel wells, placing the jack well inboard (you will see a good structural location about 18” in). That will lift the front of the car, at which point you can place jackstands at both of the front jacking points, lower the front of the car and pull the jack out.
In summary, lift the car twice and place four jackstands. Easy easy.
Tom Coradeschi
03 Boxster
08-02-2025, 11:01 PM
#662
Originally Posted by piper6909
That should work, but you don't need to do all that. The suspension and body are stiff enough that even if the lift points are off-center, the lean won't be all that much.
Here's a video:
https://www.youtube.com/watch?v=fDA-qI5HsIU
Thanks, Al. That was one of the first videos I watched when I first got the car. I like John Salt's videos.
I've had the car on jack stands four times now, using Salt's (and Tom Coradeschi's) method. Which works fine IF you don't need to elevate the car higher than 14" or so. As Salt observed, when raised at the recommended jacking points, front and rear, the car is higher on one side. There's no way around it.
My jack stands have a maximum height of almost 20", and I want every inch of that, to have enough room to drop the engine and transmission. A 14" jack stand height won't cut it. I can't conceive of any way I can achieve maximum height — on BOTH sides — without using something like my floor jack cross member to lift the car evenly and level, both sides at once. I've been thinking about this problem for a long time and I'm fairly certain my design will do the job.
So I'm going to proceed with fabrication (i.e., cutting the channel to length with a hacksaw) of the floor jack cross member, which I have dubbed "The Lift Master" (patent pending).  Any bets on whether it will work?
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
08-03-2025, 04:04 PM
#663
Rereading your post, may I assume by "With the floor jack under the rear crossmember" and "just behind the front wheel wells, placing the jack well inboard (you will see a good structural location about 18” in)," you're referring to the same lift points John Salt used in his video? Otherwise, according to Porsche, damage to the undercarriage can result.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
08-03-2025, 05:21 PM
#664
I've had the car on jack stands four times now, using Salt's (and tcoradeschi's) method. Which works fine IF you don't need to elevate the car higher than 14" or so. As Salt observed, when raised at the recommended jacking points, front and rear, the car is higher on one side. There's no way around it.
What's the lift on your jack? if it's about 22-24", then the low side should be at around the 20" you need, and the high side will be more than high enough, naturally. .
2010 Subaru Forester
08-03-2025, 07:35 PM
#665
My floor jack's maximum height is 19.5 inches. My brother's jack is approximately the same. Not enough to raise both sides to 20 inches. I could buy or make tall ramps for all four wheels and stick a platform made of 2x8s or 2x10s under the jack. That's one solution I considered. Constructing the Lift Master™  is even simpler: hacksaw 12 inches off a 48-inch-long steel channel, attach a couple of 5-inch rubber pads .— and it's finished! (Well... my OCD-lite will probably compel me to spray it yellow to match the floor jack, so there's that.) There's adequate clearance to get the Lift Master™ under the front or back with its channel upside down over the jack's pad. The pad will be in the trough, preventing the channel from slipping. The arms will extend out 18 inches (from the jack's centerline) on each side, pads positioned under the lift points.
C'mon, Al — you don't think it's a simple, semi-innovative solution?
Okay, where's Grant?!
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
08-04-2025, 03:14 AM
#666
Registered Member
I can’t say, as I’ve never seen the video. It’s a method I’ve been using since 2006. I put some photos up in a post, probably on the Pelican Parts forum, many years ago…
Tom Coradeschi
03 Boxster
08-04-2025, 10:14 AM
#667
Tom, is there another Pelican Parts forum besides this one? Also, if you want to see Salt's video it can be arranged, assuming you can present proper identification.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
08-04-2025, 05:41 PM
#668
my personal jacking procedure
This is what I do whenever I need to jack the car high on four jackstands, please note that this is my personal procedure that has worked for me since 2007 I first got my 987CS, and now I use it on the 981CS
1) get the rear wheels on ramps
2) raise the front driver side with the floor jack, enough to put a 4x4 underneath the front left wheel (this extra step is required as my car is lowered..), otherwise the jack and the piece of wood will not fit under the front bumper
3) get the floor jack centered with the frunk emblem using a 2x6x24 piece of wood under the front part of the subframe and raise the entire front, then use two stands under the facory jacking points (I use 'jack pucks' attached to the jacking points) between the jack and the frame.
4) I center the jack using the exhaust pipes as a centering point and use a 4x4x36 under the bolts that connect the diagonal braces to the rear suspension mounting points, raise the rear axle just enough to raise the wheels to allow me to remove the ramps and install the rear jack stands.
IF, needed to get the car higher, I "very carefully", slowly raise the front a bit (one click on the stands) and then move to the rear axle and do the same with the 4x4 Note: you need to raise each axle just a bit to avoid the risk of the pucks slipping from the jack stands.
Please note that I have the Quick Jack, but sometimes just thinking about the weight of the ramps gives me a back ache..
08-30-2025, 04:02 PM
#670
Thought I'd check in and prove I'm still alive and kicking. The place I bought turned out to need a lot of work. I underestimated how rough it was. But I bought it for a song, and it was built on a fairly large lot, the main attraction. I've been tied up getting it in shape — furnace, water heater, plumbing, toilet, bathtub/shower, 220 dryer outlet, roof, etc., etc., etc. Doing most of the work myself, of course, because I can. And when I get ready to flip it, the way things are going in today's real estate market, I'll probably double my money. Why not just stay here, you ask? The reason is simple: Because it's unsuitable for installation of a 2-post lift. I'm determined to have one. Anyway, I'll be back in the swap saddle by and by, count on it.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-05-2025, 08:04 AM
#671
I've been wondering where you were because I haven't seen a post from you in some time... part of me was hoping you had your Boxster all finished and you were taking a long, well deserved road trip, but I decided that thought was premature. So, glad to see your post and hope you get back to working on your car once your domestic tasks are taken care of.
Larry (the Bald Eagle)
09-05-2025, 02:11 PM
#672
09-05-2025, 05:28 PM
#673
Thank you, Larry. The ironic thing is, I'm feeling guilty about spending all this time on the house instead of working on my poor little 986. But if I don't get this house stuff finished before cold weather sets in I'll be in big trouble.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-06-2025, 03:26 PM
#674
I assumed that you guys get plenty of rain, but never knew that it gets too cold in the PNW area..
09-06-2025, 07:29 PM
#675
The PNW has freezes from time to time. The winter before last the temp dropped into the low teens. Roads were glare ice. That's the kind of weather where you'll need to have a torpedo heater on hand if you're working in the garage. I have mine, Mr. Heater. Not much of a conversationalist, but he can keep a garage toasty.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-13-2025, 02:26 PM
#676
Thought I'd take a break from installing a new kitchen faucet to give you an advance peek at the Lift Master™. To obtain enough clearance to slide it underneath the car to the lift points I use ramps under the wheels. But then, I have to use ramps with the supposedly low-profile floor jack alone. The Lift Master™ worked perfectly in testing. The car was level side-to-side at maximum jack height. I didn't take a picture because it wasn't painted yet, but more photos to follow when I put the car on jack stands to drop the old engine (although it might be a while before I can get to it).
Lift Master™ dimensions: 5" width x 1" height x 36" length. Height added to floor jack: 3/16" (thickness of the steel channel) plus 1" (rubber pads).
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-27-2025, 08:48 AM
#677
One furnace rebuild and electrical panel replacement later, here I am trying to figure out what's wrong with my 986's power windows. I made the mistake of lowering both windows just a bit ago and now I can't raise either one. They went down but would not go back up. Guess I'll have to do some research. In the meantime I'll use the car cover so the neighborhood cats don't get inside and sharpen their claws on my new drivers seat.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
09-28-2025, 09:38 AM
#678
If that happened to me, I would start by checking the fuses.
Good luck.
10-05-2025, 12:06 PM
#679
Good luck.
Fuses appear to be fine. My multimeter is still packed, so I haven't checked the relays. Wonder if the power window problem is related to the top's malfunction? Anyway, I don't have time to run it to ground. Thanks for the well wishes, Kev. I need all that stuff I can get.
2000 986 base
Arctic Silver/black
2.7 liter
5-speed manual
