Old 08-02-2025, 03:07 AM   #661
tcoradeschi
Registered Member
Originally Posted by LoneWolfGal View Post
I'm still alive, still getting things set up at my new place. In the meantime, since putting the car on jack stands will be my first order of business, I've been thinking about how to make the process less frustrating.
Consider the following:
With the floor jack under the rear crossmember, jack up the entire back of the car and place jackstands under the left and right side jacking points (just ahead of the wheel wells) and lower the car onto them.
At the front, jack from just behind the front wheel wells, placing the jack well inboard (you will see a good structural location about 18” in). That will lift the front of the car, at which point you can place jackstands at both of the front jacking points, lower the front of the car and pull the jack out.
In summary, lift the car twice and place four jackstands. Easy easy.
Tom Coradeschi
03 Boxster
tcoradeschi is online now   Reply With Quote
