		|  03-25-2023, 03:36 PM | #1 |
	| Registered User
				Idling/ stalling, no pedal response, weird ecu readings
			I was sitting in traffic and all the sudden the car started sputtering and stalling. I barely could pull into the gas station 10 feet in front of me. I am getting zero response from the gas pedal. I pulled the engine cover while waiting for a tow and the throttle body initializes for a second but doesn’t move with the pedal. I pulled up my durametric and got
P2135 accelerator pedal potentiometer
P0123 accelerator potentiometer 1
P0223 accelerator potentiometer 2
P1120 throttle plate
P1138 throttle position sensor 1
P1140 throttle potentiometer 2
P0103 hot film MAF sensor
P0132 o2 sensor before cat
P0152 o2 sensor before cat
P0138 02 behind cat
P0158 o2 behind cat
Sounds to me like all of these are connected in a circuit that’s shorted out somewhere.
Pedal value is 30.08%
Pedal encoder potentiometers are reading 4.54v
Actual value throttle is 118% even though it’s fully closed
Throttle position sensor 1&2 are both getting 5v
I’m truly at a loss. I pulled my ecu and everything looks okay nothing obvious, I saw some weird cracking but not sure if it’s just age or what. This car is supposed to get in the body shop the end of this week and I still don’t even know if it’s going to be totaled out or not. Would love to get back running again. Any help will be greatly appreciated.
		|  03-25-2023, 04:22 PM | #2 |
	| Registered User
					Originally Posted by ecp  I was sitting in traffic and all the sudden the car started sputtering and stalling. I barely could pull into the gas station 10 feet in front of me. I am getting zero response from the gas pedal. I pulled the engine cover while waiting for a tow and the throttle body initializes for a second but doesn’t move with the pedal. I pulled up my durametric and got P2135 accelerator pedal potentiometer
 P0138 02 behind cat
 P0158 o2 behind cat
Throttle position sensor and the throttle potentiometer could be on the same circuit.
But O2 sensor and MAF with the above??? very doubtful.
I would look at a wiring schematic and see if they have a common ground.
A bad common ground for the circuits or for the ECU "could" cause your issue.
		|  03-26-2023, 04:45 AM | #3 |
	| 1998 Boxster Silver/Red
			The only thing I can recommend is cancelling the body shop appointment.
				__________________1998 Porsche Boxster
		|  03-26-2023, 08:30 AM | #4 |
	| Registered User
					Originally Posted by blue62  Throttle position sensor and the throttle potentiometer could be on the same circuit.But O2 sensor and MAF with the above??? very doubtful.
I saw another thread where the issue looked to be pretty identical to what I’m experiencing, from 2007, they said they re established the ground from the MAF which was pin c9 on the ecu, but I can’t seem to find the pin out for the ecu anywhere, and also don’t really understand what it means exactly.
When I unplugged the MAF the car wouldn’t fire at all.
I reset the codes and the o2 sensor codes went away but everything else remained. I highly doubt this is something as simple as a fuse but I suppose I should check them just for good measure
		|  03-26-2023, 08:47 AM | #5 |
	| Registered User
					Originally Posted by ecp  I saw another thread where the issue looked to be pretty identical to what I’m experiencing, from 2007, they said they re established the ground from the MAF which was pin c9 on the ecu, but I can’t seem to find the pin out for the ecu anywhere, and also don’t really understand what it means exactly. When I unplugged the MAF the car wouldn’t fire at all.
Interesting that your car will not start with the MAF unplugged.
Every Boxster I have heard of will run with the MAF unplugged.
You can check your MAF wiring with a Multi Meter so you could check it's ground that way.
 You can also bring it up on your Durametric and look at voltage and if you know what to look for and how to compare it to other signals like throttle position you can test it's function.
You would have to look at the wiring schematics to figure out pin outs and grounds for various circuits.
Pin outs:
On the harness connection to the ecu each wire has a corresponding connecting  point to the ecu.
those corresponding points are called pin outs....they are also coded similar to your fuse box...so say your looking for fuse  A1 so that would be row A and 1 would be the first fuse in row A... Harness connections are set up a similar way.
Try recalibrating your E-gas (gas pedal) see if that will do anything to your throttle position codes and your potentiometer codes.
 Have you every had any water get into your interior???
		|  03-26-2023, 08:59 AM | #6 |
	| Registered User
					Originally Posted by blue62  Interesting that your car will not start with the MAF unplugged.Every Boxster I have heard of will run with the MAF unplugged.
 Pin outs:
I had some rain water get in way over a year ago but I removed all the carped and cleaned and sealed. It was just a little water behind the seats, nothing got to the immobilizer.
It hardly runs as is because all the readings on the sensors are out of wack. The reading I’m getting on the MAF is like when it’s unplugged….. reads -40c for intake temperature. There’s gotta be some common wire for the MAF, e gas and throttle body.
I’m getting 5v on the MAF and throttle position sensor, 30% pedal value. Throttle body does not move with pedal, reads actual throttle position at 118%. I just don’t know what would make it go out sitting in traffic. It’s been dry here for quite a while, and the car was running fantastic earlier in the day
		|  03-26-2023, 11:07 AM | #7 |
	| Registered User
					Originally Posted by ecp  I had some rain water get in way over a year ago but I removed all the carped and cleaned and sealed. It was just a little water behind the seats, nothing got to the immobilizer. It hardly runs as is because all the readings on the sensors are out of wack. The reading I’m getting on the MAF is like when it’s unplugged….. reads -40c for intake temperature. There’s gotta be some common wire for the MAF, e gas and throttle body.
The water issue:
I was more wondering if things got wet around the base of the gas pedal.
That is where the e-gas (potentiometer) is.
try recalibrating the throttle see if it has any effect.
And or disconnect the battery for an hour or so and see if the ECU will reset with default values.
5v is usually reference voltage .....the signal voltage from the ECU.
		|  03-26-2023, 02:26 PM | #8 |
	| Registered User
					Originally Posted by blue62  The water issue:I was more wondering if things got wet around the base of the gas pedal.
Never water up there. I thought it was up under the dash? Since it’s drive by wire, unless there’s multiple. The pedal feel is definitely different, I’m going to try that and also unplugging the pedal to see what readings I get.
		|  03-26-2023, 02:54 PM | #9 |
	| Registered User
Disconnected the pedal still says 30% throttle position. With my durametric I’m getting an extremely erratic MAF airflow reading. It’s running extremely rich to the point of smoke coming out of the exhaust (no cats). It bounces up and down at idle like a bad vacuum leak only it’s just sputtering and running horribly.
It seems like it’s trying to adapt to whatever the issue is but is still thrown way off
		|  03-26-2023, 06:16 PM | #10 |
	| Registered User
					Originally Posted by ecp  Disconnected the pedal still says 30% throttle position. With my durametric I’m getting an extremely erratic MAF airflow reading. It’s running extremely rich to the point of smoke coming out of the exhaust (no cats). It bounces up and down at idle like a bad vacuum leak only it’s just sputtering and running horribly. It seems like it’s trying to adapt to whatever the issue is but is still thrown way off
If the engine is not running smoothly your going to get erratic MAF air flow readings.
The more erratic the engine runs the more erratic the MAF airflow readings will be.
Did you try disconnecting the battery for a few hours???
That will force the ECU to default settings.
Then before you start it re-calibrate the E-gas.
To do that reconnect the battery.
Turn the key to the on position but do not start or crank the engine.
Wait one minute turn key off for 30 seconds.... then restart the car.
See if any of that does any good.
When you say you disconnected the pedal what exactly did you do???
		|  03-27-2023, 05:04 AM | #11 |
	| Registered User
					Originally Posted by blue62  If the engine is not running smoothly your going to get erratic MAF air flow readings.The more erratic the engine runs the more erratic the MAF airflow readings will be.
I unplugged the potentiometer under the dash. I unplugged the battery for a bit and it looked like all the fuel trims reset, but still no difference, when I try to clear the codes with durametric they do not go away. That tells me either wiring issue or issue with the ecu, but don’t know where to look.
Should I start testing the grounds to throttle body and MAF? Can I use continuity with my multimeter? I think I found a couple diagrams showing the ground wire for each, and in theory I should have continuity to any ground on the car? The plugs on the ecu look good no corrosion and they’re not loose. I tried wiggling them around to see if a wire on the plug is loose but no resolve. Seems like the wire for the MAF is on the third plug of the ecu from what I’ve found.
Maybe I can test for continuity between the ground on the maf and throttle body as well?
		|  03-27-2023, 06:05 AM | #12 |
	| Registered User
					Originally Posted by ecp  I unplugged the potentiometer under the dash. I unplugged the battery for a bit and it looked like all the fuel trims reset, but still no difference, when I try to clear the codes with durametric they do not go away. That tells me either wiring issue or issue with the ecu, but don’t know where to look.
You said your gas pedal felt different.
My guess is that your E-Gas potentiometer has gone south. "But it is just a guess"
there are numerous wires that go to it.
I think your best bet at this point is to take it to a shop that is well schooled in electrical issues with theses cars.
Continuity testing by it's self is not that reliable....... this is why I say that.
Wires are made up of multiple strands.
It only takes a single strand to show a connection "continuity"
So all the strands in a wire can be broken except one... that wire will test as good because it shows "continuity" on the single strand.
But the wire "circuit" will not function because there will be to much resistance from the broken strands.
Continuity test are only reliable if the wire is completely broken "no continuity" or used in conjunction with resistance testing.
So again I think you need a shop schooled in electrics specific to theses cars.
Sorry I can't be of more help.
		|  03-27-2023, 08:32 AM | #13 |
	| Registered User
					Originally Posted by blue62  You said your gas pedal felt different.My guess is that your E-Gas potentiometer has gone south. "But it is just a guess"
I appreciate all the input. It does feel different. And it started inching in traffic, it revved way up when I gave it a little gas and then started missing and died. I ordered a used pedal with potentiometer. I’m wondering if it’s still in “limp” mode with the pedal disconnected because it’s getting zero reading and that’s what it defaults to now. I hope I can get it by Thursday. I’m going on a trip and still have the body shop and insurance to deal with. Just want to drop it off and not have to worry about these headaches.
Fingers are crossed that the pedal and a hard reset of everything will correct it.
		|  03-27-2023, 09:59 AM | #14 |
	| Registered User
					Originally Posted by ecp  I appreciate all the input. It does feel different. And it started inching in traffic, it revved way up when I gave it a little gas and then started missing and died. I ordered a used pedal with potentiometer. I’m wondering if it’s still in “limp” mode with the pedal disconnected because it’s getting zero reading and that’s what it defaults to now. I hope I can get it by Thursday. I’m going on a trip and still have the body shop and insurance to deal with. Just want to drop it off and not have to worry about these headaches. Fingers are crossed that the pedal and a hard reset of everything will correct it.
Just a guess on my part here but.....
 With the pedal disconnected the ECU will see conflicting signals from the potentiometer and the throttle position sensor.
they work together..... you probably know this.... but as you press the gas pedal the potentiometer sends a signal to the throttle butterfly to tell it how far to open.
So my guess is if the pedal is disconnected or it has a fault the ECU sees nothing or a signal that does not make sense from potentiometer at the same time it is getting a signal from the throttle position senor. So there is a conflict....ECU's don't like that.
Wish I could be more help but trying to diagnose an issue remotely is very difficult when they are typical issues.
Your problem is far from typical....
Please keep me posted on what you find what the fix is that sort of thing.
You can PM me or just follow up on this thread.
Good luck with it.
		|  03-27-2023, 06:33 PM | #15 |
	| Registered User
					Originally Posted by blue62  Just a guess on my part here but.....With the pedal disconnected the ECU will see conflicting signals from the potentiometer and the throttle position sensor.
 Good luck with it.
I’ll post a follow up when I find some resolve. Poked around at some wires and traced some harnesses. Took the pot out of the car and tried testing the resistance but since there’s 6 wires it was harder to try and figure out what was what. The red and violet wire carries 5v to the gas pedal, and is also connected to the throttle body. I traced it back to the ecu so i at least know that wire is connected properly. I tried jiggling wires around while the car sputtered. The maf is hooked up to the ecu properly. If I could figure out which wires are what on the maf and throttle body I could be sure that they have correct voltage.
I’ll keep poking around at stuff after work until the new pedal and pot arrives
		|  03-27-2023, 08:05 PM | #16 |
	| Registered User
					Originally Posted by ecp  I’ll post a follow up when I find some resolve. Poked around at some wires and traced some harnesses. Took the pot out of the car and tried testing the resistance but since there’s 6 wires it was harder to try and figure out what was what. The red and violet wire carries 5v to the gas pedal, and is also connected to the throttle body. I traced it back to the ecu so i at least know that wire is connected properly. I tried jiggling wires around while the car sputtered. The maf is hooked up to the ecu properly. If I could figure out which wires are what on the maf and throttle body I could be sure that they have correct voltage.
If you DM me your email, I'll send you all the wiring schematics.
My guess it's 1 of 2 things
1 - there are only a few common ground points in our cars. Multiple circuits ground to a single point. If one has become corroded (or damaged - we're you in an accident?), it could effect multiple electronics.  This could also be true of wiring bundles - if you were in an accident and a bundle was pinched it could short multiple sensors.
2 - your ecu is shot
I'm hoping for 1, but Occam's razor may be pointing at the second (especially if there are signs of physical damage to the casing)
If I were you, I'd roll her to the body shop and have her totaled. Get the cash and then decide how much its worth to sort this out. That's just my 2c though.
Sent from my SM-N975U using Tapatalk
				__________________2000 Box Base, Renegade Stage 1 performance mods complete, more to come
		|  03-28-2023, 04:25 PM | #17 |
	| Registered User
					Originally Posted by ike84  If you DM me your email, I'll send you all the wiring schematics.
I pmd you. I have continuity to ground on the 5v and ground for the accelerator pedal. When I measure the 5v and ground wires on the harness (one end of the multi meter in each) I get .84v and 1.20v for each power and ground circuit. If I go from signal wire to ground I get about 4.5v from each harness. There is no continuity to ground on the signal wires.
Is this telling me there’s a short somewhere in the harness? Or is the dme providing no voltage to the pedal because it’s malfunctioning?
		|  03-28-2023, 04:55 PM | #18 |
	| Registered User
			I'm not very good with circuit testing, and my girl is put away for the winter (yes, we still have snow on the ground) so I cant give you any reference values. Maybe someone can post theirs for comparison?
I can tell you for a fact that the car should start and idle normally with the pedal harness disconnected. I know this from when I played around with a pedal commander type device - you will just have a dead pedal.
Typing all this out makes me remember a video I saw a great while back - someone noticed that their potentiometer was sticking and acting up so they disassembled and lubed everything and that fixed the problem.  If your pedal has a "different feel" that could be another possibility (sorry, I missed that post or I would have mentioned it earlier).  Something maybe worth trying would be to disconnect the pedal and then fire her up. If she idles smooth, you have your problem.
If it is the pedal,  78f350 can probably pull one for you and ship it to you for a reasonable price. He even throws in a bonus goodie
		|  03-28-2023, 05:38 PM | #19 |
	| Registered User
					Originally Posted by ike84  I'm not very good with circuit testing, and my girl is put away for the winter (yes, we still have snow on the ground) so I cant give you any reference values. Maybe someone can post theirs for comparison?
Sent from my SM-N975U using Tapatalk |
It runs different, but still bad. Same with the maf when I unplug it. Then when I press the brake it shoots up to 2k rpm smoothly and shuts off. I saw the thing about cleaning the pot. I got a new to me low mileage one arriving tomorrow. Doubtful it’ll fix the issue. I was reading a thread on renntech that seemed to be describing exactly what I’m experiencing but it seems the conclusion was the dme was faulty.
I’m going to try unplugging maf throttle body and gas pedal and starting and seeing what happens. When I unplugged the maf it seemed like it was trying to adapt and settled on a steady chug instead of constant misfires. Oddly enough I got zero misfire codes.
Should probably pull the firewall behind the seat and look at the harness for anything obvious.
		|  03-28-2023, 06:11 PM | #20 |
	| Registered User
			I ran a hardwire from the MAF ground to chassis. Throttle body initialized, car fired right up. Smooth sailing from here? I’ll have to attach it properly but this seems promising. Breathed a sigh of relief when it started.
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 04:29 AM.
