Old 03-14-2020, 04:56 AM   #8
piper6909's Avatar
Originally Posted by flouese View Post
My problem is that I can’t get a screwdriver in there and be able to put enough torque on it to get the set screw to turn going to search for a 90degree small screw driver and see if that helps. Any suggestions on a better plan?
I can't remember what I used. Try a driver bit in a 1/4" socket and a 1/4" ratchet. Or maybe just the bit and the socket without the ratchet. The socket's diameter may be enough to give you the torque you need. Tip: if you use the bit in the socket, tape them together so the bit doesn't fall out and make you waste tons of time searching for it.
