Old 03-14-2020, 03:56 AM   #8
piper6909
piper6909's Avatar
Originally Posted by flouese View Post
My problem is that I can’t get a screwdriver in there and be able to put enough torque on it to get the set screw to turn going to search for a 90degree small screw driver and see if that helps. Any suggestions on a better plan?
I can't remember what I used. Try a driver bit in a 1/4" socket and a 1/4" ratchet. Or maybe just the bit and the socket without the ratchet. The socket's diameter may be enough to give you the torque you need. Tip: if you use the bit in the socket, tape them together so the bit doesn't fall out and make you waste tons of time searching for it.
piper6909 is online now   Reply With Quote
